any fans buying? XD
Is the diff between using pro controller and the joycon holder (bundled with the switch) big?
Sent from Xiaomi REDMI 4X using GAGT
The authentic pro controller is really quite expensive ********* and I'm not envisioning alot of multiplayer games hahaha. Maybe I should buy the 3rd party cheap cheap ones to try
It takes up to 10 days to receive the email starting from the day u redeemed the points at eshop. For me, i received the email around 3 days later.
If you bought Smash digitally, you do not need to do anything, the Piranha plant DLC will autimatically download once available.
If you bought the physical copy, you will need to do the "earn points" route and the email will be sent to the email associated with the nintendo ID that earned the points. Do check your spam, promo folders (esp for gmail).. i found the email with the Pirahna code in my Promotion folder in gmail after 3 days once I registered by clicking on the "earn points" as you did.
Hope this helps!
Comfort factor aside.. the convenience factor also matters.. you no need to take in and out the joy cons. Esp. so if your Switch has a silicon case or similar.
i got 2 sets of joycon for that purpose![]()
Comparison chart for the latest Xiaomi and zmi power banks
Sent from Xiaomi MI MAX 3 using GAGT
mine mostly party games or mario so joycon works fine
will be getting 1 pro controller at least
Pro controller built quality, design (mine's the basic), comfort, battery life, all ish KY.
just bought a pro controller too and have to say the quality and comfort is really good but no doubt expensive. can hook up to pc anot? my xbox controller spoil riao![]()
Can share lobangWhat's the cheapest price for switch now? The cheapest I saw is $399 after $50 coupon.
Can share lobang
Sent from OPPO CPH1611 using GAGT
