Nintendo Switch thread - Part 3
Glariel
Like that buy local set better.
I found 1 seller that sells at $390 after discount
Elysium87
*shakes head, only $400+ Item scare this scare that...
well it's his/her money. to some ppl 400 is not much, to some ppl 400 is alot. it's not like he's/she's being a nuisance. it's their own decision to buy or not.
you could have just ignore/disregard it.
Srenz209
Do I need Nintendo online to play Diablo 3? Can I link with my PC battle.net account and play with existing characters?
KingOfSbw
Yes you need the subscription for online co op
Not able to link to exisiting PC account, different server
DrBaldwin
You also do not need the online subscription to play Seasons. Currently Season 16 (started a few days ago).
No linkage to BNet also.
b0ib0ii
Planning to get a Splatoon 2 in Carousell. How to ensure that the game is in the US region? Is there a way to check through from the game casing?
temytemy
I just started Season 16, using female Necro. First time playing Seasons, I don't know how it works. Previously playing Single player barbarian, it is quite imba on high levels.
jonnieboy
same.. first time playing season using Monk..
KingOfSbw
I started WD 2 days ago, first time using it
Now lv 67 liao
Heng heng gotten leoric crown jus 10min into playin haha
KingOfSbw
Monk i used it last season, not easy in the beginning as will be close range combat
But once u up to 70 and get the neccessary set, u can be ranged fighter liao
