Oneplus 5T
deathst
Dun get you or you mean the carrier details when enabling the volte?
I used India-VoLTE-Vodafone as shared in OP6 thread.
which profile did you use?
Not sure for M1 and ST, SH and TPG are working, the VoLte changed to VoWifi when i am connected to wifi.
Did u enable wifi calling in settings?
At least you can see the switch (I thought can see that switch means working?). Using Singtel SIM can't see this switch at all.
Sent from OnePlus 5T using GAGT
I highly suspect that is a bug right now.. TPG officially only support 1 phone for VoLTE and that is the Huawei Nova 3i
https://www.tpgmobile.sg/topic/74-tpg-volte-supported-devices/
jtec14
I think not a bug bah, hardware wise the phone can support volte, only need the local carriers/telcos setup the necessary configurations which they are doing for the more common phones only. So we merely using foreign carriers/telcos' configuration which are already setup for oneplus devices. Anyway the workaround worked for 5t/6/6t also so doubt it is a bug.
Gixxerfied
IMHO not a bug, it's something which OP hardware supports but OP has not included the profile for SG VoLTE in it's firmware update(Same goes for many user in Europe/India).
Tested just now when i touch down SG, can make calls to my M1 voip line, can call in using my M1 voip line and can send sms to my M1 line.
sunht
Just upgraded, don't feel much difference with Android 8.1.
The volume control on 9.0 is really PITA. Torrible experience to adjust ring volume.
onlinehero
with the new update, there's no Bluetooth icon on the status bar when Bluetooth is on?
Sent from OnePlus ONEPLUS A5010 using GAGT
onlinehero
are you using this case? does it add like a significant amount of bulk to the phone in your opinion?
used the spigen rugged armor when I first got my phone and I didn't like the added bulk of the phone so I had to let go of it. currently using the Ringke fusion but if this does not add significant bulk may consider getting this :D
shichuanhua
I using it on pocophone ,
i think the thickness around the same as ringke , weight about 35g
lousydrinker
Anyone got problem with Google pay after update to 9.0.7?
lousydrinker
In case anyone looking for red OnePlus 5T. I like to get but price too high. Might as well get OnePlus 7
OnePlus 5T 8GB Ram 128GB (1 Year Official Warranty) | https://s.lazada.sg/s.gLgA
Sent from Xiaomi MI 9T using GAGT
