[Official] Playstation 4 PS4 club - Part 3
PierceLee
Kingdom Hearts 3
IGN: 8.7
Gamespot: 8
Edit: Gamespot removed their video yesterday and just reposted it
PierceLee
Dragon Quest Builders 2 (Chinese ver) gameplay:
Has photo mode and can upload (see @52:20). OMG, the game just came out, and the things people built are crazy, this is beyond Minecraft.
shin7829
Just came to know there are two release of Atelier series soon
Nelke & the Legendary Alchemists: Ateliers of the New World
JP 1/31/2019
US 3/26/2019
EU 3/29/2019
Atelier Lulua The Scion of Arland
Daughter of Rorona o_O"
JP 3/20/2019
US 3/26/2019
EU TBA 2019
now no need to wait for 6-12 months for English sia
o_O
PierceLee
JP 1/31/2019
US 3/26/2019
EU 3/29/2019
JP 3/20/2019
US 3/26/2019
EU TBA 2019
o_O
Lulua is the 4th game in the Arland series, should be the traditional Atelier gameplay. Nelke is a spin-off, it's like town building sim + RPG, though it has the main characters from all the 19 previous games.
Chinese official sites:
https://www.gamecity.com.tw/atelier/nelke/system01.html
http://www.gamecity.com.tw/atelier/lulua/
shin7829
dio brando
awaiting english version since its fast
Lulua no issue. Nelke... i feel should wait for more info/be cautious.
i don't mean to offend atelier fans.. Nelke looks like chup cai png to me. all MC mix together like mobile game does. battle screen even got a auto button.
littleredboy
I downloaded netflix app on ps pro, but the icon cannot be found?
Have to open via the notification.
What happened sia? I know theres a ps3 version to be downloaded, but im pretty sure mine is ps4 version.
PierceLee
Should be inside the "TV & Video" folder
knightshaz
High Honorary Member
Yes, Netflix not like Spotify appear in main row. Need to dig the TV & Video folder.
Layers
RE2 reviews are up:
ACG: absolutely worth going out there and getting right now
IGN: 8.8
Gamespot: 9
Easy Allies: 9
haven't bought a first
day release game for a long time.
nv play their series b4. but i love town building!
fk-ing intensive!!! :s22: love it.
got play in darkly lit room?
Sent from Samsung SM-N950F using GAGT
Layers
RE2 take up alot of HDD space!
I know PS4 support installing in external HDD. My brand will do? do i need to get one with a PlayStation supported one?
rudylili
No worries, any brand will do because once u plug in your HDD, it will prompt to format into their format. But be sure your HDD is empty before plugging in.
PierceLee
Ya, any brand will do. Make sure it's USB 3, not USB 2.
Better to buy those with brand rather than buying a USB casing and assembling your own, cos for an external HDD you want to make sure the electric power it receives (from PS4 via the USB cable) is enough and stable. HDD technology improves over time, if you use some old HDD and put a casing, it's possible that old HDD may need more power input.
As pointed out, if you use a USB HDD as extended HDD for PS4, that whole HDD will be monopolised by the PS4. You cannot use it for anything else (PS4 will format it, PC will not be able to read it). Once you set up an extended HDD and later decide to upgrade to a even bigger one, there is no tool to transfer the data, have to re-download everything, so use a big enough HDD. There is a minimum size that PS4 allow, can't remember how big, can expect that if you have some old 60GB or 120GB lying around, probably can't use them (they probably draw more power anyway).
Also note that the extended HDD cannot be used to backup your PS4 save files.
PierceLee
RE2 remake now has Chinese voiceover DLC (free):
SG PSN download: https://store.playstation.com/en-sg/product/HP0102-CUSA12497_00-BH200VOICEDLC001
Let's play, with Chinese voiceover:
