SGX EOD Data
choychho
I am not able to download SGX EOD using DataServerSg for the past 2 days too. In fact, I have not received Data Adjustment for months already. I have been writing emailssss to "contact@technical-analysis.com" but so far no reply.
I am beginning to wonder if they have run out of business
hybrid200x
I think I understand the problem now.
Just last week, my script was still working fine. Today I realised that sgx website has changed the URL format for running its API to pull the data file SESprice.dat.
Its an easy fix. And my guess is once they (DataFolio or DataServerSG) realised the change and implement remedies to their own scripts, all shall return back to normal. But till then, you will have to bear with the inconvenience. Good luck!
klarklar
Seems like DataServerSg or DataFolio as known in the old days is dead. No reply from the person who sold the software. It is ok to wind down the business and stop support. But at least please give your customers some warning first as some of us depend on the product to make money. I don't think it is nice to ignore customer emails when the product stop working. Some explanation from the person is expected. At least tell us with a firm answer whether this product is officially dead and that we should go look for alternative. Don't give us silent treatment.
peterchan75
I suppose it may be due to the "new" Term of Use.
Point 2 of 2nd paragraph ... :s22:
Still can get the data and parse them to the your format or get from Yahoo Finance.
jas663
Anybody can recommend SGX EOD data source?
Have been using datafolio and now sourcing for others....
TIA
Sibehsiok1
Still no reply despite several emails. At least the admin should provide feedback.
Not helpful at all.
choychho
I have since been downloading daily eod from SGX and written a Excel VBA to convert the .dat format into a metastock format. Finally use metastock downloader to update the EOD. Hope the above give the metastock users some idea on how to overcome
hybrid200x
If anybody needs it, i have the entire collection of sgx EOD data since 1996 till now.
libratiger74
Hi, anyone has a better option to share for Dataserver now since it is clear it is not supported anymore and there is no response? Thanks.
peterchan75
Here is a solution using Excel macro. Create a excel macro and delete whatever in the Microsoft Visual Basic editor and paste the VBA code below and save it under .xlsm file in a folder. It will consolidate all the SESprice.dat file in the same folder as the .xlsm file in Sheet1 and format Sheet2 column A as text and key in all the tickers that need to be consolidated. Download the SESprice.dat from SGX website and give it a unique name with .dat extension.
https://www2.sgx.com/research-education/securities
The consolidated output will be in SGX_EOD_output.csv.
Excel VBA code
'Start a new Excel spreadsheet, click Macros button, View, Create
'Name the macros at SGX_EOD and press enter
'There should be Sub SGX_EOD() and End Sub. Delete them.
'Copy and paste these codes
'Put all the SESprice.dat and this macro in one folder
'Need to rename SESprice.dat files to some unique name
'The filename must have .dat extension. Otherwise, it will not be read
'In column A of Sheet2, format it to Text
'In Sheet2 of the macro workbook, put in SGX ticker starting from Row 1
Sub SGX_EOD()
Dim thispath As String
Dim inputfile As String
Dim outputfile As String
Dim eod_linein As String
Dim eod_lineout As String
Dim ticker As String
Dim date_str As String
Dim eod_array As Variant
Dim i As Integer, j As Integer
Dim found As Boolean
outputfile = "SGX_EOD_output.csv" 'If you want, you can rename it
thispath = ThisWorkbook.Path
ThisWorkbook.Sheets("Sheet1").Columns("A:A").Clear
FileList ("*.dat")
Open thispath & "\" & outputfile For Output As #1
'If do not need label then just comment out the following statement
Write #1, "<Ticker>,<D>,<YYMMDD>,<Open>,<High>,<Low>,<Close>,<Volume>"
For i = 1 To ThisWorkbook.Sheets("Sheet1").Cells(Rows.Count, 1).End(xlUp).Row
Open thispath & "\" & ThisWorkbook.Sheets("Sheet1").Cells(i, 1) For Input As #2
While Not EOF(2)
Line Input #2, eod_linein
If Len(eod_linein) > 0 Then
If IsNumeric(Mid(eod_linein, 1, 1)) Then
eod_linein = Replace(eod_linein, Chr(13), "")
eod_array = Split(eod_linein, ";")
eod_array(14) = Trim(eod_array(14))
ticker = eod_array(14)
found = False
For j = 1 To ThisWorkbook.Sheets("Sheet2").Cells(Rows.Count, 1).End(xlUp).Row
If ticker = ThisWorkbook.Sheets("Sheet2").Cells(j, 1) Then
found = True
Exit For
End If
Next j
If found Then
date_str = Mid(eod_array(0), 3, 2) & Mid(eod_array(0), 6, 2) & Mid(eod_array(0), 9, 2)
eod_lineout = ticker & ",D," & date_str
If eod_array(8) = 0 Then 'No trade, set Open, High, Low to Last
eod_lineout = ticker & ",D," & date_str & "," & Abs(eod_array(6)) & "," & Abs(eod_array(6)) & "," & Abs(eod_array(6)) & "," & Abs(eod_array(6))
Else
eod_lineout = ticker & ",D," & date_str & "," & Abs(eod_array(12)) & "," & Abs(eod_array(4)) & "," & Abs(eod_array(5))
'Check for delay close
If Trim(eod_array(15)) <> "" Then
eod_lineout = eod_lineout & "," & Abs(eod_array(15))
Else
eod_lineout = eod_lineout & "," & Abs(eod_array(6))
End If
End If
eod_lineout = eod_lineout & "," & Abs(eod_array(8))
Write #1, eod_lineout
End If
End If
End If
Wend
Close #2
Next i
Close #1
End Sub
'Sub to read ".dat" files in current folder and store to Sheet1
Sub FileList(fltr As String)
Dim i As Integer
Dim fldr As String
Dim sTemp As String, sHldr As String
fldr = ThisWorkbook.Path
If Right$(fldr, 1) <> "\" Then fldr = fldr & "\"
sTemp = Dir(fldr & fltr)
ThisWorkbook.Sheets("Sheet1").Cells(1, 1) = sTemp
If sTemp = "" Then End
i = 2
Do
sHldr = Dir
If sHldr = "" Then Exit Do
ThisWorkbook.Sheets("Sheet1").Cells(i, 1) = sHldr
i = i + 1
Loop
End Sub
Sibehsiok1
Hi, can u provide the steps to write excel via to convert the sgx dat format into metastock format. Do I nid to install vba app in excel? Plse help..thks
choychho
I tried to post the dropbox link but was rejected by admin. Sorry I dont know how to help
whitesand
Can you email me the steps please? (email PMed).
Thank you very much
whitesand
Anyone has good source of SGX EOD data for metastock? I don't mind paying a (preferrably small :) ) fee for that. Thanks.
Adriana Lowe
Maybe try Sigma by Hydra X - it's a new platform with free data feeds for most markets including SGX
klarklar
Hi, has anyone tried datafet.com for eod data?
This certainly looks good. Too good to be true, to be honest. So, be careful. On the other hand, if you have tried it and find it good, do share with us your review. I'm sure there are some disadvantages since it looks too good to be true.
