- Mar 31, 2001
using ocbc also no such problemUse DBS internet banking would save you the trouble of trying to figure out this thing.
we have uncle kenny here. for him 5x ers also can
10x frs possible?
What's a birthday year? Your birthday falls on leap year only?
Perhaps rrr2015 is asking about newborn Singaporeans? Yes, newborn Singaporeans are allowed to make voluntary contributions to themselves. However, ordinarily newborns struggle with writing checks or using AXS at age zero, and compulsory contributions aren't too common within that cohort. (A few infants with careers as models?)
apologizes, should have made myself clearer.
I was thinking about the year when i turned 55, if I'm able still be able to VC. I understand that at 55 I can do RSTU, just not clear if am able to do VC
learn something new about CPF contribution to newborn. thanks!
You can do VC beyond 55, and even beyond 65!
However please note that the portion going into SA drops significantly post 55.
I may not be 100% correct but I will give it a shot.
- in order to reach ERS you will need to do a top up from FRS to ERS.
- If you then opt for BRS, only the FRS portion is considered (ie topups are excluded from the calculation of the withdrawal portion.)
- the portion that you can withdraw is FRS-BRS (= BRS). The topup from FRS to ERS will have to remain in our RA together with the initial BRS. The amount remains in RA will be = 2xBRS (or FRS).
- Hence you will now have BRS+(ERS-FRS) for your CPFLife, plus a charge against your property for BRS plus interest. You can withdraw BRS from your RA with this charge.
noted & thanks! waaa ... SA portion going to drop more than 50%!
After you start payout at 65, all your RA goes into CPFLife Premiums, and your RA becomes $0 right?
In this case, you can top up again to ERS.
So it means 2xERS (1 ERS in CPFLife, and 1 ERS in RA) ?
just wondering during birthday year ... are we still allow to make VC to self?
No, you can't.
If you have 176k at 55 and all of it, including accumulated interest, goes into CPF Life Premium (for Standard and Escalating Plans), you can only top up RA to the prevailing ERS less FRS of 176k.
Anyone managed to do the following:
Hit FRS (without transferring from OA to SA) before 40?
The Full Retirement Sum is $176,000 for 2019. The maximum inflow into the Special Account for those under age 35 is $6,120 per year, rising to $7,140 from age 35 to 45. Excluding interest, and focusing on the lower figure, that's equal to about 28 years of contributions.Quite impossible without transferring Nor topping up.
A well compensated actor or model who starts working in Singapore as a child could pull this off (hit the FRS before age 40 without OA to SA transfers or SA top ups). That's not altogether impossible, but it's pretty darn difficult.
