Official MIO TV Thread.......
jonleelk
Hey thanks for the reply. Mine is definitely a Singtel ONT. Say so on the box. I had a free 2-month SingtelTV trial last year and the technician was able to set up the Singtel TV box in the living room without any problem. I think it was ONT -> Asus router -> cat5e -> switch -> TV box, but I can't be sure now.
The problem now is that I want to watch TV in the bedroom too but I think my Asus router only allows Lan port 4 to be configured for Singtel IPTV.
Your suggestion gave me an idea. Anyone can advise if this will work?
ONT/ONR(??) port 2 -> cat5e -> bedroom switch -> TV box & other devices
ONT/ONR(??) port 1 -> Asus router (AP mode if ONR) port 4 -> cat5e -> living room switch -> TV box & other devices
Asus router port 1 -> cat5e -> study switch -> other devices
On a separate note, how much did you pay for the 2nd TV box and any additional subscription costs?
If u are going to use 2 STB, I guess that will change your ONT to an ONR. As long as u have cat6 cable running in the house to where u want to place the STB, no need to worry.
Additional STB is at $5.90 per month.
mun_hoe
if i would like to return the setup box, can i go all singtel outlets?
you will need to call singtel 1688 and inform them of your intention to terminate and then later proceed to return the STB at any of their hello singtelshop (not exclusive retailers)
WestGuy
Woah HBO channels are now on Singtel TV.
Free trial till end Feb, available at $13.98 a month after.
parklum
Otherwise, you can return Singtel TV equipment at the following locations:
Singtel Shop Comcentre
31B Exeter Road, Comcentre 2, #01-00 S(239733)
Mon - Sun / PH : 10.30am - 7.30pm
Singtel Shop Tampines Mall
4 Tampines Central 5, Tampines Mall #02-13/14/15 S(529509)
Daily: 10:00am - 10.00pm
Singtel Shop Causeway Point
1 Woodlands Square #03-03/04/05 Causeway Point S(738099)
Mon-Sun/PH: 11:00am - 9:00pm
Singtel Shop Jurong Point
63 Jurong West Central 3, Jurong Point Shopping Centre #B1-98/99 S(648331)
Mon - Sun/PH : 11.00am - 9.00pm
Thanks.
Hi
i don't seem to locate the above information at Shirley, the virtual assistant
i manage to find only
https://www.singtel.com/personal/support/replacement-centres but not this info
mun_hoe
the thing is i am already on Jingxuan value which includes Fox movies. Now HBO comes in and is another premium addon. Will see how are it's offerings for the trial month
yperic
Finally HBO is on Singtel tv what other channel starhub have that is not singtel tv yet
Shion
Senior Mentor
BBC
Smithsonian
Blue Ant
CBeebies
Gusto TV
Makeful
PeopleTV
Travelxp
Asia Travel
2 x Phoenix
TVBS
TVB Xing He
etc etc
Shawncck
Singtel TV go on android box
Hi, anyone know if Singtel TV go can be installed on android box and view? I have the app on my iphone but if can be use on android box then i can view on tv... Any idea?
p_eppermint
I’m also using m1 broadband at home, thinking of getting mio tv. Does this mean that as long as we have a fibre point available it’s possible?
I tagging my parents one since Singtel tv cannot be tagged in M1 broadband and you guys don’t offer free installation for fibre point for Singtel tv
renfred89
You should have 2 ports. The OpenNet terminal point that your modem is connected to using optical cable would have 2 outputs.
Yes that right. If you are signing another ISP for internet deployment, then second port activation could be free as part of the contract. But solely for singtel tv, user might need to pay though, not too sure of the rules now.
tank_t
I have a singtel tv subcription at my parents place. Then i move out.
Can i rent another singtel tv box at my own place to watch singtel tv?? But i dont have singtel fibre..
Please advise.
tazmic
Hi folks, I'm currently on starhub and quite keen to switch to Singtel Mio TV. But i have a problem. I need 2 TV box, one for living rm, and one for room. The living room has a network point, but my room has no network point where i put the tv box.
Does MIO TV box comes wireless? Or is there any other options such taht i can have a 2nd box in my bedroom?
