chesterqw
- Dec 29, 2006
https://www.sony.com.sg/electronics/support/downloads/00015638 Looks like the latest update allow you to change but I'm not sure..
Oooo new firmware
soon can upgrade the ear pads for the M3. I ordered the suede ones for my M2. waiting for it to arrive.
https://dekoniaudio.com/filter/?product_cat=sony+wh1000xm2&product_cat=sony+wh1000xm2
Not yet out for xm3 walao you made me happy for a moment there.
Hopefully new earpads can make the xm3 less of a earmuff for cold weather
Anyone using this for gym? Afraid might spoil if Kean sweat. Comments?
https://www.massdrop.com/buy/dekoni-premium-ear-pads-for-sony-wh1000xm2
Ear pads available for xm3.
I got the suede for the xm2. Feels nice.
i m using xm2, it gets hot in abt 1hr, so do these ear pads help?
Is the Suede washable?
How's the suede compared to synthetic leather in terms of comfort and passive noise insulation?
The earcups on my xm3 do not look like they can last past 12 months to be honest... Esp in our climate
Posted from PCWX using Motorola StarTac
there're reviews each claiming both are better than the originals, so far, only one review said he got both leather & Suede, he will use his leather mainly. Probably he prefers the leather.
For me, i chose Suede cos for our weather, leather probably not a gd choice. my only concern will suede difficult to clean? I emailed them if suede can be washed, no reply.
Does the suede earcups seal as well in terms of noise insulation?
I think there are suede shoe cleaners but i do not know will they stain...![]()
I just ordered from Amazon. have to wait till i got it before i can comment.
Sorry if i keep asking about the passive noise insulation... But i saw many commented about them poorer than the original...
Check out carousel alsoBeen wanting to hoot one of these, but the price has been always a problem. zzz. Then recently came across these refurbished set.
https://www.lazada.sg/products/sony...42.searchlist.list.23.18e062cetI6Vo1&search=1
These refurbished set worth the purchase? or the risk is too big? cost around priced at $358 at lazada![]()
