FuNKySoULyBrO
- Jan 1, 2000
recommend to buy?
My personal opinion, for rrp of $400+, nope. But if u can get a deal down to say less than $300, probably ok.
recommend to buy?
I noticed one issue that happened occasionally, especially for those who dun put in the charging case when not in use.
I normally don't bring along the charging case for my daily trip to work. So at work, just leave it there for it to auto turn-off.
However, sometimes, when I turn it on to use it on my trip back home, left ear bud no sound/not connected. Right earbud seems ok. Not sure is it battery dead or something else....
that is usually when battery is low. i experienced it quite a few times and after i charged it the problem goes away.
Does anyone know if Qoo10 hongkong set has international warranty?
Does the E8 have any lag while watching YouTube or videos etc? Any recommendations to get E8 or E8 v2.0? Is it compatible with older devices like iPhone 6s or better to use it with newer phones? Would gladly appreciate any suggestions. Thanks in advance!
No lag. The only difference between E8 and E8 v2.0 is the inclusion of a re-designed wireless charging case and new colours. Other than that, the earbuds are basically the same. It should also be compatible with iPhone 6 series.
Thanks for the info! Btw can the strap be removed from the E8 charging case or is it permanently there?
Another thing to ask, how long is the battery life of the ear buds and with the charging case? Is it suitable for jogging/gym too?
After a year with the Beo e8, I've decided to ditch it. Bought a Sony wf 1000x and couldn't be happier.
e8 is not meant for everyone. The tip is very short and is not meant for those who needs a long tip to have it sit snugly. I couldn't get a good seal for the music to sound good. Comply tips improved it somewhat but still was a "forced" experience. Had to push it in real hard to get a good seal. The left side also become softer than the right side too. Some said is due to firmware update but I'm not sure.
