Huawei Mate 10
Paul Lee
When using Easy Projection by connecting a HDMI-to-USB C cable, it defaults to the Desktop mode
Does anyone know whether it's possible to default to the Phone mode instead? Thanks!
TheOutsider
You can set it under Device Connectivity -> Easy Projection -> Projection Mode I think. I never use it though so you have to try :D :D
amazingone
New update for Mate 10
Posted from PCWX using HUAWEI ALPS
oberin
Not sure whether this is posted, I updated to latest software and same day found that Volte able to work for TPG already.
mikeymesina
I just got the update today and same case for me. Now can make calls using the TPG sim.
Sent from HUAWEI ALP-L29 using GAGT
amazingone
Tried with TPG card, and VoLTE really works on the Mate 10.
Thumbs up for Huawei to support the older Mate 10 too. :s12:
TheOutsider
Anyone find that the camera and also night mode photos are getting worse the more it update. In Oreo, the AI photos turn out much better. I will be happy to use any photos coming out of the camera app with AI on (no option to turn off in Oreo anyway) but that's not the case with the Android Pie camera app. Night mode photo turns out more smudgy than that in Oreo. Anyone thinking the same?
OutBreak
Maybe I am WOLS. I just went back to Nova Launcher Prime. The guesture seems to be smooth and fluid now. It works like a part of EMUI. :D
CS0287
:D
Wow thanks for the notice man.. it's working fine so far... Back to Nova launcher now... Hahaha
