Painting Sealant
kyteo79
Not sure what I have, anyone knows what is this insect
I email nippon and they never tell me what is that photo and say if got mold/mites, say use this
https://www.nipponpaint.com.sg/trade/products/product-listings/anti-fungus-solution/
Dulux say maybe booklice
Are these mold? > Photos of wall and ceiling https://imgur.com/a/BriiHmu
Why not get them come and give you a quotation and ways how to resolved it ... of course you must be sincere in engaging them lah ...
i am very confident they will go a fantastic job ... of course at a premium price...
rubber33
ju5tme
Leaving sealer to dry overnight before painting finishing paint
Nippon sealler typically just need 2 hours of dry time. If I finished the sealer nearer to sunset, can I leave it to dry overnight and paint the finishing color the next day?
In other words, it is not necessary to paint finishing paint exactly 2 hours after painting sealer, am I right?
djr81
Of course can..
Min 2 hrs of drying time are required..u can do it the next day or later is ok..
:s22:
ju5tme
Of course can..
:s22:
thank you very much.. :s13:
now I can finish sealer for the all the wall and take my time before start to paint finishing color.
paopei
You need to call pestbuster for them to do misting to kill all existing book lice. Book live reproduce very fast. Did for my entire resale unit cos it was mouldy and had book lice in unit. Misting in all toilets bedrooms living room kitchen.
After misting, we did another site
Inspection 2 weeks later and it was all clear. We then painted our house with sealant, anti fungus and anti mould paint.
Probably the book lice are located in other parts of your house and cos your room is more humid it may gravitate towards your room?
Hi, could you please DM me the pestbuster and the removal of mould plus painting? My study room and living room have lots of booklice. After we cleaned, it will come back after few days. Our bathroom ceiling have black mold. Thinking to engage the pestbuster and mould removal service. Appreciate if you could DM me the contact and name. Thanks a lot
super365
I wonder what is the long-term solution for preventing mold and booklice? Maybe you ask them how to prevent mold. Should we buy a dehumidifier or do something else?
Does your booklice look like the insect I posted earlier?
I only wipe the walls with water a bit of soap and microfibre cloth. A few months later that insect and mold will reappear. I think mold once formed it will always reappear. Did not paint new paint yet.
warhol
Hi, any updates on your situation?
I seem to be in the same predicament; reno completed in Feb, 2 weeks after moving in I noticed these tiny insects primarily on the MDF wood that my contractor used for certain parts. Observed 2 types; one smaller one that crawls quite slowly, and the other one hops around fast.
Been 4 months now and I notice what seems to be mould growing on it (3rd pic). Am I wrong to suspect that my contractor might have used mouldy wood or used watered-down paint on them?
super365
I have these insects like your photos also on the walls. I wipe with water then reappear wipe again. Very sad not sure about long term solution. I think need a good dehumidifier. I googled and I think is due to humidity, not sure about materials and paint. My walls after painted now already over 10 years plus no such insects, only these few years then have, maybe the paint become older attract mold or maybe humidity rises.
From what I read, I think cleaning it is only temporary solution, I think need to maintain it insect free must really go and buy a dehumidifier. If you all have any good dehumidifier to recommend do recommend, need quiet.
https://www.peststrategies.com/pest-guides/lice-guides/get-rid-of-booklice/
https://www.rentokil.com.sg/blog/book-lice-walls-tiny-black-dots-see/
https://www.thespruce.com/how-to-get-rid-of-psocids-2656435
super365
I just wipe my room ceiling and wall with Clorox, no booklice for two days. But came back on third days again although volumne is lesser than before. Could they be coming from the holes in my ceiling? There are many holes in my ceiling, some small size some slightly bigger.
Did you all solve your booklice/mold problem already?
Did the problem come back again? If no, what is the thing that you did to prevent the problem again?
Did you buy a dehumidifier?
Is there any insecticide spray for these insects?
Thanks
Taryyip
How long has it been since the house has been booklice free? No more booklice found since the last visit by pest controller?
Did you also had to buy dehumidifier and use aircon more often to keep the humidity down?
Taryyip
Did you engage a pestbuster? May I know which company? Was it effective and you do not see any more booklice?
Taryyip
Thanks
Did u engage pestbuster? Mind sharing what's your plan and updates on situation?
super365
Never engage anyone.
I wipe the walls using 3M super mop. Wet mop with water then wipe. This is the only thing I do now. Still got those book lice/mold appear but lesser. If more reappear I wipe again.
Will buy dehumidifier later on. Now humidity in room is about 75% so I guess thats why mold appear.
Will repaint the walls next time, now no time and I am also not sure if repaint will solve the problem forever. Worry waste time and effort repaint and still mold appear. If dehumidifier can prevent mold and booklice then I feel safe to repaint. I also worry if those mold/booklice are hiding somewhere maybe like inside air con pipes, gaps, cabinets, lights/trunkings worry after I repaint they might come out of their hiding place and reappear on walls then all painting effort wasted.
I am wondering is there off the counter stuff spray that can kill all the the mold/booklice before I paint, like those insecticide spray.
Taryyip
Why did u choose not to call in pestbuster? And mould inspection/ removal service?
Budget concern or you are convinced they cannot resolved the issue
Taryyip
Are you or family members psychologically affected by the presence of booklice?
Did you find any in wardrobe. Did you inspect other areas like drawers and such to see if it has also infected those areas?
How long has it been? Are u wiping daily?
Sorry for the many questions. Really hard for me to find anyone facing similar issue and willing to share updates.
super365
I think pestbuster should be able to solve the problem but will it be solved forever I guess still depends what you do after they left, cost is a concern I guess maybe expensive so I rather try cheaper way like dehumidifier first then see how. Even if pestbusters can solve the problem, next time I think still need dehumidifier to maintain at 50% humidity. Too humid mold will appear. All these are by theory so not really sure why not all people have mold, maybe some places higher floor or lower floor or more windy or different paint or whatever maybe also will affect differently. You can buy a humidity meter to test how humid your room is, what I know is 50% is good humidity. For me I guess pestbuster will be last option.
I am more affected as I like to be clean. This does not happen to whole flat, and not really obvious as I cleaned it already, but I know it will reappear so I am affected by it tired to wipe again, do want to solve it forever.
Wardrobe have some mold, I wipe wardrobe yearly, and now I put in thirsty hippo in wardrobe and very seldom have mold in wardrobe. Never find the booklice in wardrobe. Booklice in normal cupboards sometimes. Been like a few years. Usually I wipe one time can last like a few weeks/months no problem, sometimes see 1 or 2 booklice just wipe it away. Never wipe daily. If you got try anything next time do post here to share also. Not sure how the other people solve also.
Do you on air con most of the time? I know air con will reduce humidity. I on air con I see humidity drop slightly, but I do not on air con frequently and my air con is old not strong. You can try after cleaning mold or booklice then on air con for maybe 1 week/month without turning off, I guess that 1 week/month maybe no mold or booklice appear then I guess is humidity problem. I am guessing maybe low humidity the mold and booklice auto die and then wipe once then solve the problem. If you do not have dehumidifier, on air con is just to do testing what happens if slightly lower humidity but not real test as my air con cannot reach as low as 50% humidity, a real dehumidfier sure works better than air con to reduce humid.
"Sometimes, humidity or dampness (water vapor) in the air can supply enough moisture for mold growth. Indoor relative humidity (RH) should be kept below 60 percent -- ideally between 30 percent and 50 percent, if possible. Low humidity may also discourage pests (such as cockroaches) and dust mites." source https://www.epa.gov/mold/mold-course-chapter-2
"Air that is too dry has negative health effects for occupants. Target 30 – 60% RH for optimal occupant wellness (eyes, skin, nasal)"
"Research shows a link between low humidity and the likelihood of flu
• Our body defenses are stronger above 30% RH
• There is less infectious flu virus in the air at higher RH levels
• The likelihood of flu infectivity decreases at higher humidity levels"
source http://www.ahrinet.org/App_Content/ahri/files/Humidity_Occupants_Presentation.pdf
Yr0gErG
Hi, I also have a increasingly bad mold situation in my resale flat, renovated and moved in early 2016. Decided to repaint in Nov as all my efforts to scrub and repaint did not stop the mold from coming back.
Not sure if fellow forumers have heard of Gush paint company. Decided to try them as I have 2 young kids and wanted something that is odorless, zero VOC and anti mold.
I was told that the only way to stop mold is to have plenty of cross ventilation, sunlight if your space allows for it. Difficult as no one is usually at home. And the AC unit lowers the humidity but tends to cause condensation on the walls that are not cooled, I.e the adjacent rooms.
I emphasize with your struggles with mold! ))::
super365
How long have you used gush paint? Did any mold appear after using gush paint?
What is the meaning of cross ventilation? Bedroom door always closed and only open windows can it be cross ventilation?
