Redmi Note 7
noobiee
lol i confused alr, wanted to compare pocophone with note 7 pro instead
but then note 7 pro dont know when will announce also
oh well
ccmheoa
Sama sama pocophone 845 will cream note 7 pro 675 as well...best bang for buck is still pocophone
oh well
garychengjw
Hard to beat Poco price point at this time.
Sent from Xiaomi POCO F1 using GAGT
Audiology93
Saw qoo10 259 for note 7. But poco is definitely more than 326, where you see?
Shopee usually a lot of flash sale for pocophone F1 where it was as low as $336(around there) for 128GB after stacking coupons + coins + shopback.
Sent from HUAWEI Mate 20 using GAGT
teawithmilk
Recently bought the Note 7 for my dad at Shopee for $280 (6Gb/64), because of the $30 off for $300. The camera is not bad, especially if you install and use GCam to utilise Night Sight.
matrix05
So how you handle Google play store installation? and any problem with Whatapps & TPG data?
tang_tang
Use Google installer V3 from miui forum.
Sorry. Is it same like using other android phone like Samsung after install the Goggle installer? Still not very sure about Global rom and China rom. All they way..i am using Samsung phones and thinking of changing.
teawithmilk
Oh..the seller helped pre-install google play. Installed a couple of apps (like firefox etc.) and it works. Haven't tried whatsapp yet but should not be a problem
tomsss
Does your GPS work properly? Cos mine doesn't, it may lock on position at first but the coordinates won't move. Have to turn off and on gps to locate new position and again hangs there.
End up I have to flash a new gpsconfig file to have it working normally.
amazingone
100 sets of Redmi Note 7 Pro.. :o
Posted from PCWX using HUAWEI ALPS
davidwong
For Sg / India or for cn? If SG meaning we won’t get the special cn version?
Update: on zooming in the picture the wording is Chinese so must be cn version =:p
Just Me
China rom is ok if you're not too particular about GPS usage. Transport and apps like grab/foodpanda use it and it can take a bit of time to lock on to the correct location
Sent from Xiaomi MI MAX 3 using GAGT
