MayBank SaveUp Programme
luvalist
Oh just saw the cap interest so even by doing so, $120k earns bonus interest. $80k earns 0.3125%. Forget it man.
bright_84
For privileged saveup, I was thinking of opening 2 saveup accounts under 1 name, each put $100k. Three cat to hit:
1. Salary (account 1) / giro (account 2)
2. $800 spending (under same name so hit $800)
3. Deposits of $200k in aggregate
(https://info.maybank2u.com.sg/privil...saveup-faq.pdf
But since 1 person can only have 1 saveup, I dunno how to interpret the “deposit” criteria.
Read and read but can’t figure this out. Did I miss out something?
Means you put 200k in 1 deposit.
bright_84
Then they shouldn’t put ALL saveup accounts with the SAME primary holder!
Annoying banks. 1.12% might as well put FD
They write it like that so that if they change their rule and allow multiple save up don't have to change document.....
power_range
Why do banks do such things?
Kept changing their terms and conditions, and making us do so much hard work, shifting our money here and there.
So far only CIMB has been consistent.
ThreeSteps
It is advisable to read the below t&c updates carefully.
Note: Save Up Programme will be revised from 1 April 2019:
Terms and Conditions for Save Up Programme: https://info.maybank2u.com.sg/pdf/cards/saveup-tnc.pdf
FREQUENTLY ASKED QUESTIONS ON REVISION OF SAVE UP PROGRAMME: https://info.maybank2u.com.sg/pdf/cards/saveup-faq.pdf
The Bonus Interest is only applicable to the first S$50,000
Note: Maybank Privilege customers with Save Up Programme will be automatically enrolled to Maybank Privilege Save Up Programme from 1 April 2019.
Terms and Conditions for Privilege Save Up Programme: https://info.maybank2u.com.sg/privilege/docs/privilege-saveup-tnc.pdf
FREQUENTLY ASKED QUESTIONS ON PRIVILEGE SAVE UP PROGRAMME: https://info.maybank2u.com.sg/privilege/docs/privilege-saveup-faq.pdf
The Bonus Interest is only applicable to the first S$100,000
Trazora
Already discussed in this thread. Note also salary crediting and giro no longer counted as 2 categories. Very tough to meet 3 criteria. Also no point to go for priviledge save up. Time to switch out.
power_range
I switched over to UOB - because easier to hit the criteria, and also easier to set up the 3 giros - UOB card payment, and IRAS payments.
