use the routing table at the bottom under the openvpn client tab..
firstly please make sure you have reserved static IP for those devices..
the last radio button is a killswitch for the selected devices. if you select "yes", no internet traffic will be allowed on the listed devices if your vpn server is disconnected. if you select "no", then the listed devices will fallback and connect to the public WAN again.
the routing policy in this pic is set for the listed devices to connect thru vpn while all non listed devices to connect thru public WAN.
just need to click on source IP dropdown list to select the device, then click Iface dropdown and select VPN and click add.. destination will be auto populated as 0.0.0.0.
if you wish to do the opposite and have the devices in the list to have public WAN access while all others on VPN, select WAN instead of VPN under the "Iface" dropdown list when adding the device/source IP.
*edit* sorry forget to mention something important. you need to change the "Redirect Internet Traffic" option first before the policy routing table will even appear..
https://i.imgur.com/ZRmBJXm.jpg[/mg]
[img]https://i.imgur.com/tfGO0YU.jpg[img]
Sent from Samsung SM-G965F using GAGT[/QUOTE]
Thanks!
10 chars
