SaLvAtoOo
K. Tks very much! Will look into it.
An example for your reference:
Code:
- alias: Balcony Motion Turn On Light
  trigger:
    platform: state
    entity_id: binary_sensor.motion_sensor_158d0001d90b27
    to: 'on'
  condition:
    condition: and
    conditions:
    - condition: state
      entity_id: switch.wall_switch_ln_left_158d0002b73ca8
      state: 'off'
    - condition: or
      conditions:
        - condition: sun
          after: sunset
          after_offset: "-00:30:00"
        - condition: sun
          before: sunrise
          before_offset: "00:15:00"
  action:
    - service: switch.turn_on
    - wait_template: "{% if states.binary_sensor.motion_sensor_158d0001d90b27.attributes['No motion since'] | int >= 180 and states.binary_sensor.motion_sensor_158d0001d90b27.state == 'off' %}True{% else %}False{% endif %}"
    - condition: state
      state: 'on'
    - service: switch.turn_off
pajamasguy
Hi all, i am currently playing with xiaomi home automation although i have got both the gateway and zigbee plugs for quite some time.
I am facing the problem of automation rules not running when the wifi is down. For example, i set my handphone plug to turn off at 6am everyday but it does not do so if wifi is not available. It does so correctly when wifi is available.
Does anyone xiaomi users encounter this and is there a way to overcome this?i thought that zigbee devices should be able to work without wifi.
Tia
automation triggered by zigbee sensors will still work without internet connection but not timer schedules. how will it knows the time when it is not connected to the internet?
pajamasguy
Hi everyone, was told by my electrician that having a neutral wire is dangerous as I'm not intending to automate yet. Just building it in as part of reno.
He mentioned that it could cause electrical fires. Do the experts here have similar concerns?
neutral wires are already at the lights and power points, just not at the switch points. why should it be any more dangerous at the switch points? your electrician either doesnt want to do it or he doesnt knows what he is talking about
SaLvAtoOo
the electrician is saying if dont terminate..meaning leaving the wire unterminated at the switch point.. coz maybe owner heaven decide what switch to buy...
anyway, the simplest and cheapeat way... jus dark tape the wire...
SaLvAtoOo
i tried and all automation dont work.. as long ur gateway has no internet... automation doesnt work.
unless you code your automations in HA.
pajamasguy
Oh sorry I read his question wrongly then. In that case, just don’t cut the insulation and tape up the ends.
As for automation not running if no internet, mine works cause I’ve experienced it before. But I’m going to test it again.
halth
Ah yes sorry if im unclear.
The light switches are just going to be simple malia legrand switches for now. So there is no termination point.
Hence the electrician is saying could be unsafe.
pajamasguy
It’s safe if he tapes it up. Not like it’s gonna move around on it’s own. Just mark the wire properly as well so you know it’s a neutral.
zoneguard
HASSMART products
Is anybody using these?
Taobao Shop
Link to forum for products
They have:
1. 86mm Wifi touch switch. The same product supports both neutral and non neutral with capacitor.
Looks like it uses Tasmota
as the GUI is identical. Espurna also supported.
2. Module to convert normal switch to smart switch. Non-neutral also possible.
3. 16A module to convert wall socket to smart one.
4. Curtain motor.
pustefix
I've also tried before and using Mi Home app, the automation will still work if it is Zigbee only and you lose internet connection. e.g. motion detected will still turn on a wall switch. Timer scheduling will NOT work though, it seems the gateway doesn't have a clock to keep track of time.
pajamasguy
this is what i tested today - with my wifi turned off
1. notifications dont work
2. timer dont work
3. zigbee sensors all working - can turn off or on light switches. timer set using motion sensors still works (as in If no motion detect after 5 mins Then turn off lights)
xwhitefangx
If I pull 1 neutral line from light to switch, can this neutral line be used other switches beside it as well?
Posted from PCWX using ALP-L29
Hi everyone,
I'm very new at this but i'm trying to learn more about this, any help is appreciated.
I am doing renovation at the moment and thinking of putting neutral wires.
However i have a question regarding pulling of neutral wires, does the neutral wire need to be taken from the junction box(DB)? or connected to the DB directly?
Or is there a neutral point at the ceiling light bulb area where i have to use a neutral wire to connect it to the switch area? without connecting to the junction box? Dont really understand it.
Also if there are any links to read more about this i would love to learn.
Thanks!
sellun
Hi everyone,
Thanks!
Think this picture should help you understand clearly..
Sent from HUAWEI BLA-L29 using GAGT
pajamasguy
Hi everyone,
Thanks!
Some neutrals are separated into 3 phases. Some just go back to one neutral line. If you use a neutral from a separate phase you may trip the breaker.
A qualified electrician will know what to do., where to tap it from etc
xwhitefangx
Thank you, yea so I'm not sure where to tap etc
anyone have any electrician's contact who can help with this to share?
seianko
Suspended
ER....
hdb only running 1phase in ur own dwelling
different phases neutral is for 3 phase pwr and you dun have that in ur own dwelling, unless u stay in landed bunglow
either u buy 2c+E or just buy twin core cable, where when u split it it will have a N and a R.
N will run back to the N-bar
Earth goes back to Earth bar
1 N cable will terminate at Earth bar
Load to Load
Active to Active
without Neutral, behind the switch usually is labelled as 1C2 or 123, where 1 or 2 is the common and C is the live
punkster
Regarding neutral wires, is it right to say you only require it if using smart switches?
For Eg the Xiaomi ceiling light seems like no need for the neutral switch and I just need to leave the normal switch in the ‘on’ position?
