Redmi 7
amazingone
Remembered previously at Redmi 6 event they said users feedback 2/16 version has too little RAM and ROM hence the model base started from 3/32. Now they brought back the 2/16 version. Very odd.
Posted from PCWX using Redmi Note 5A
Maybe they abandoned the A series :eek:
limjialok
Yeah, then what's the point for getting Redmi note7 when Redmi 7 is almost same size and same battery
1) FHD+ screen vs HD+ Screen
2) 48mp camera vs 12mp camera ( even though not true 48mp)
3) Snapdragon 660 vs snapdragon 632
davidwong
What are you going use the phone for or who are you gonna buy for?
Basically if from specs it’s about the same as Redmi note 5 pro.
Single to duo tasking. Slight stuttering for FB if you have video auto playing (muted). Good battery life. YouTubing no worries. Forget about games or minimal at Low settings.
Passable bright day light camera. Forget about dim restaurants food taking or night scenes.
Fm radio avail.
Dual Sim with SD card.
Good for TPG for streaming media
So the note7 has the edge over processing power? Don't look like a big difference in experience though
Jurong640
Fm radio avail.
Yeah, probably gonna use it for my TPG/MyRepublic sim for videos and some light gaming. Best if there is FM radio. Camera so so can liao as currently using Note8 for primary phone
amazingone
If you do light gaming, then can consider getting the Redmi Note 7 (non-Pro). It's more worth the value for a little more top-up.
But the Redmi 7 is able to support dual SIM and micro SD together at once, if you need it then can consider the Redmi 7.
limjialok
Fm radio avail.
Yeah very slightly worst than rmn5. But rmn5 seems like the better buy , unless u wants the notch
davidwong
Actually depends on the type of game this bro is looking to play, as most of my friends who are looking at the price range mainly using it as streaming box and also the games they are play usually are moba or 2D rpg strategy game (from China) hence in Low settings should be passable
Most importantly will be the pricing.
Which as I said I think mi Sg miss the boat by pricing the note 7 abv the Sg ppl psychological pricing line of below 300 for a mid range secondary phone.
ahwei91
quite many ppl hooted the redmi 7 during shopee flash deal (till 8am)
