samsung pay
MIVEC525
Officially started today. As long as it’s a MasterCard it should work. Just get your watch ready before reaching the gantry and tap
Ok...so just activate samsung pay on watch and tap like making payments?
ngsoonle
Going to try on bus later. Really scared will hold up the q...will standby card just in case
ngsoonle
Didn't work on the bus I was taking. Really need to standby card. Will try using phone tomorrow
PongRareRare
How did you do it? Screen on or off?
I'm assuming you need NFC on when screen off but when using screen on, at Samsung Pay, no need NFC to be deliberately on as it can on by itself
shadlightsg
I used with screen off. Quite fast too. But only got 10 Samsung points for 2 trips.
Sent from Samsung SM-G975F using GAGT
ngsoonle
Was using my galaxy watch. Maybe I should try touching my bezel on the reader instead
aw1007
That's correct, my OnePlus worked on MRT (via Google pay)
Sent from OnePlus 5T using GAGT
No option for our local ezlink system in Gpay?
trenzterra
How do I check my transport cost amount? For some reason Samsung pay only shows 10 cents deducted...
deathst
You will need the SimplyGo app. Make sure you got an account and link your MC card there. Then you can get notification of the journey cost
nanotech25
You will not always get the samsung rewards points correct? Only when there is that 10cent charge then will have points. Is it the same for everyone?
