I sent the entire unit except the hdd. Mine doesn't have power brick hence i did not include it.
.NAS die faster than HDD
In my case, my ds414 power brick got issue just 3 months after purchase. EA replaced the power brick on spot and unit worked fine still I sold it end 2017.
Best to have local warranty for NAS.
Might be worthwhile to go for a DIYNAS next time hor?
i think of getting from tb... and than diy if spec is gg
https://post.smzdm.com/p/a3gz0e9d/
Thank for the link, had placed order from taobao to replace my aging 2 bays synology
Just got myself a DS418.
Dealer informed to register warranty online with Synology.
RMA will be back to dealer who will assist RMA to Synology (distributor?).
I've registered an account with Synology and device however it doesn't say it's an actual warranty registration. It doesn't even ask for my purchase info.
Anyone here actually registered their NAS' warranty online?
Need to keep the receipt.
Can advise how to best set up the Synology NAS for external access?
1)
I'm having trouble accessing some services externally, in particular the Drive web-app (desktop client seems to work fine).
On the router, manually forward every single relevant port or just set as DMZ?
2)
If I have my own domain name, how do I point it to the NAS?
Thanks a lot!
That's it? So no actual online warranty registration.
1. Your choice on dmZ or manually set
2. Your domain should have an option to configure the IP address in. Alternatively u can map it via ddns.
Refer to this list for supported IP cameras.Anyone with Xiaomi Mi Home IP camera and able to store to the NAS?
I am thinking to buy a NAS if the IP camera could connect to NAS.
Entirely depends on a couple of things:Thanks, I will go play around with it. First time owning a domain name
