Anyone using M1 big data plan
tt32003
Feels like this plan most worth it to me now
As I don't usually make that many voice calls
Mostly use data only
Just like to know about the free 100 sms that comes with the plan as compare to usual 1000 sms for normal lines
Is that for sending sms ?
Or receiving sms also counted as 1 ?
If just sending think more than enough for me
eric3743
Receiving or incoming SMS is always free.
The one who send the SMS already paid for it either part as free or payable.
lohsenglte
Note that if you're eligible for MSS/MLS/Corporate discounts, the mySIM plans (mySIM 3/E) will not be applicable. Only the Voice+ plans (Lite/Lite+/Reg etc) is eligible.
tt32003
Right now I'm using lite+ with 2G data add on
So if switch to cheapest mysim will save $7.60 per month
Same 5G data but less talk time and sms which hardly use
So thinking about switching
But mysim to recontract after 20 months need to pay $50 . Still cheaper than Lite+ though
lohsenglte
2GB add-on as in Upsized Data?
Btw, if you've any school ongoing children or NSF, you can actually apply for Youth Benefits. Subscriber can still be your name, while having the child's benefit. Extra 2GB/Mth for free for the 24 months contract.
Red8310
How's the data? Will it often disconnect as compared to normal plan? I worried although they give you big data but the data is not good?
Any users can comment?
Jurong640
Huh? It's M1. It's the same reception and data speeds. Not plan dependant. I've been using for years
