Redmi 7
K202020K
anyone using the redmi 7 yet?
i had notice a issue , when i on the phone wifi & launch wechat, whatapp or youtube. The phone seem to response dame slow to access the application. it would show black screen for ~ 5 to 10 sec.
I would need to close the app, clean out then re-launch it. Seem each round when i off & on the wifi this would occur.
I dont have this issue on any of my xiaomi phone except for this.
Where you buy from?
Local or export set?
China or global ROM?
Sounds rather weird
What is it's RAM/ROM configuration?
3GB/32GB? Not enough RAM for Android Pie?
Paging for the AmazingOne ....
foxer77
Where you buy from?
Sounds rather weird
local set from one of the qoo10 seller
Global rom 3GB/32GB. That why puzzle me.
seem like software bug..
K202020K
If it's software issue
Would be fixed in Mi system updates lah
No worries bro
In the meantime can execute a hard reset of the device?
foxer77
No worries bro
reboot the device but still the same. Now hoping for new update loh.
K202020K
Bro not reboot he is asking you to factory reset. Also you want to check whether is there an update you can update to?
Not factory reset lah
Hard reset by pressing combination of power button & volume up, volume down buttons OR
Press and hold down the power button for more than 10 seconds
Depends on the brand/model in question
foxer77
Switch off your phone.
Power on your phone while pressing Volume up button + power button.
A menu appears on the screen. ...
choose your language.(select via volume +/- buttons,and choose via Power button)
Now choose Wipe and Reset option.
think this the one he wanted me to try
K202020K
Yes
But can try the easy 10s power button reset out first
Always carry out the simple methods first before proceeding further
Good luck.
ahwei91
Xiaomi Redmi 7 64GB + 3GB Ram export set - shopee flash deal tomorrow 18 april 12pm to 2pm...
current price : $209
flash deal price : unknown yet
ahwei91
Xiaomi Redmi 7 64GB + 3GB Ram export set - shopee flash deal till 2pm
$195
matrix05
$195
Prices not really interesting because RMN7 3/32 can get $205 on Q10, also export set with Cn Rom. extra $10, can play pubg.
K202020K
$195
小米 Redmi 7 with 3GB/32GB and
One year local warranty support
Now available for S$185
Store so much inside the native storage space
If phone died
Sure cry for 3 days & 3 nights
Better to keep inside the dedicated microSD card
Phone spoil just move data to another working device
Not unduly stressed out yo
8-lane
If phone died
So have u decided on what phone to get?
ahwei91
If phone died
important data must backup la no matter it is on internal storage or sdcard...
phone can spoil, sdcard can spoil too... :s22:
having more internal storage still better la... since most(or maybe all now) apps can only install on internal storage...
having more internal storage does not mean you cannot use an sdcard too mah...
if buy too small storage, sure cry for 3 days & 3 nights when cannot install all your fav games...
ahwei91
btw, I'm just posting info abt flash deals... never say a 3/64GB export set is a better buy than a 3/32GB local set...
K202020K
哈哈 ....
No hurry
Just taking it easy lah
For me, when come to shopping for things
Often depends on my mood and fate
My mother used to say
If not fated to buy an item on that day
Walk around the whole day also come back home empty handed one
Right now I've got other matters to attend to too
8-lane
哈哈 ....
No hurry
Lol ic.. the phone u wanna get is for ur helper is it?
K202020K
哈哈
C'mon lah
You think my Chinese horoscope sign is Snake ar ?
Seriously considering the Realme 3
But hesitant as I dislike Mali GPUs
No LED notification light
And no selfie flash unlike the Asus Live L1
