Are we able to use phone to pay for buses and mrt now?
Posted from PCWX using ALP-L29
Usbc port?port easy spoil. known isssue. sending in to huawei service center in orchard
how does this work? is there a specia requirement on the card linked to Google Pay where it has to be NETS-enabled or Flashpay enabled or something?Via Google pay. So yes
Posted from PCWX using HMA-L29
It has to be a Mastercard debit/credit card.how does this work? is there a specia requirement on the card linked to Google Pay where it has to be NETS-enabled or Flashpay enabled or something?
I set monthly limit. It will prompt me if I exceed the daily average.Possible to set daily limit for data? Just wondering.
Sent from HUAWEI BLA-L29 using GAGT
Thanks. Anyway using tpg also? Can't seem to find the network.I set monthly limit. It will prompt me if I exceed the daily average.
Sent from HUAWEI MATE 10 using GAGT
No. Singtel.Thanks. Anyway using tpg also? Can't seem to find the network.
Yes is possible
Take a look at this site FAQ for more info. Under Mobile Payment
FAQ for Mastercard Contactless Cards
For Google Pay to pay for public transportation, look at the following for more info.
Use Google Pay for transportation
Does anyone here use google photo? If you are, does your phone sync with the app? I have been trying to sync the app to upload my photos but it's not working. Tried clear cache also don't work...
You mean the one under settings right? I have enabled that. When I load into the app, it will show me the number of photos to sync with a circle behind. But I waited with my wifi on, the number doesn't decrease at all... IDK why?I've using it to sync the photos on my phone. have you enabled the back and sync option under the Photos' Settings?
Thanks!
It seems that for the Google Pay, I can't add any of the travel pass. It only allows me to add Las Vegas Monorail and myki. NO support for SG.
For the Translink, I've already had the card activated.
Ezlink/Flashpay support only coming later this year if not wrong. I tried too to no avail. If google can find some info on this haha
If you are using MasterCard, it will works . Just tap as per normal wireless payment in shop.
I just tried this morning, able to deduct directly.
but I did register for simplygo before I tried, not sure if it matters.
