The Spectacles Thread. - Part 2
joesph
Anyone knows where I can do lenses only at a cheap price? I'm a student and Owndays is too expensive for me :/
foptics near kovan. $35.90. open days 1 3 5, 6p.m. make appointment. collection 3 days
Sent from Samsung SM-G975F using GAGT
Aneosx
Hi all,
i just went to get my vision check. it says spr +0.25, cyc +0.25 and axis 90. Do i ned to get prescription glasses?
Aneosx
isit necessary to get a glasses, or is tat jus a v slight refraction error on my eyes?
Hi all,
Hi!
Your degree is considered very mild. Not necessary to make glasses at all.
Probably just drop by any shop 1 year later or when you start seeing blurer. :)
ralliart_ray
Where to find the best price for 1.67 transition lens ah... or usually all locked by RRP
Yup, small plastic frames are recommended when using lenticular lenses for best effect. Lenticular lenses are still available with progressives. We'l normally recommend to those with super high prescription (usually >-10.00D). :s13:
Just for reference.
Update:
Had a customer recently change progressive lenses for his own frame.
Degree is -9.75D.
Old lens :1.74 index Progressive
New Lens:1.74 index Progressive Lenticular
Lens thickness went down by about 20-25%
GANGSTERKIA
Any difference at the front too? For comparison sake e.g. diminishing effect of the myopic rings.
Just for reference.
Update:
Degree is -9.75D.
LIN_JOEL
Guys I needed some advise.
My specs had been broken, so I wearing another pair that I made in JB and which I suspected the reading is incorrect as I feel giddy.
However I ignore it worn in almost half a year until my baby accidentally break it.
Now I'm wearing contact lenses with the same degree but I realized when I'm unable to see text in close distance.
Holding Hp or papers approx 20cm away the text is blur but ok if I took out the lenses or spec.
Am I having 老花眼?
Any recommendation to test and make a new specs as it affect my work.
GANGSTERKIA
Good evening,
How old are you roughly?
Any idea what is your power right now?
There was a similar incident to a user here too, whereby he used same power of lenses with his glasses and thus have issue reading.( no power compensation when having you are over the limit for contact lenses).
Am I having 老花眼?
