86technie
- Jun 8, 2006
49”
Just normal tv programmes and movies and netflix
That soundbar is only 80 watt, if you don't need a loud soundbar than this is suffice.
49”
Just upgraded my android box to hook up to my Sony 65" tv but got image no sound on my Bose 321 system. Using optical cable to connect tv to the bose with no issue on sound viewing normal tv programs, etc. After configuration on setting audio on the android box still no sound until I discovered that to have sound while viewing movie fr the android box I need to unplug the hdmi cable n replug every time...eg every movie need to unplug n replug the hdmi cable in order to detect sound. Anyone can help to fix up this issue. I don't mind to pay to hv this issue fix up.
Ensure that Bose 321 the optical setting is set to TV.
If no sound than at the TV set the optical output to PCM.
Bose 321 unclear whether can it handle Dolby signal from the TV.
Probably you have to set aside budget for a soundbar to pair
with your TV.
No issue with my older android box which was able to detect sound from the Bose 321 under Sat CBL setting. Just that after changing to a new android box got issue on sound. Need to manually unplug n replug the hdmi cable to the tv port then got sound. You know of anyone who is able to provide such service regarding this issue? Don't want to buy a soundbar since the Bose 321 is serving me well all these years.
Typically you have to play around with the setting at your
Android box.
I am looking for Samsung rear speaker model SWA-8500S. Bought the soundbar N650 and this seems to be the only rear speaker options. Looked everywhere but all out of stock, anyone have idea where to get it?
Thank you
Nah I non gamer, would prefer a musical one, so which one would u recommend is it the Yamaha yas108Gaming? Creative Katana...
Otherwise, if you don't mind 1-month warranty only, Sony S200F for $215 on Qoo10 :X
Bought 2 sets 7 months ago and still good
But if you are going to pay full price for that, go for Yamaha instead?
Personally I would prefer clear audio then loud bass but muddy audio
Thanks!
Just tried the HK 1300 Enchant, and IMO, it's a good system for the money:
https://peteswrite.blogspot.com/2019/04/harmon-kardon-enchant-1300-review.html
I wouldn't recommend the yas-108. The bass distorts.
