squidy
hey guys....which setup out there can let me use voice control without....for example,
Fibaro -- ok google let me speak to Fibaro or ok google ask fibaro to turn on the tv
homey - alexa, tell homey to turn the lights
I not really sure whats the activation words like but i know its something like the above.
any setup out there can simply tell fibaro or homey to, "ok google, turn on the lights" instead of adding on additional "ask Fibaro/tell homey"?
SaLvAtoOo
with home assistant.. u can achieve "alexa, switch on living room lights"... same to google home
punkster
I like the idea of Home Assistant but due to the latest firmware update i cant pair my new xiaomi gateway anymore (unable to get developer key)
What are the other alternatives (localised network) that supports various brands but particularly xiaomi and google home? If it has a decent UI would be a bonus as compared to spending my wkend editing yaml files:s13:
Vulpix
Moderator
Moderator
You do not need to say "let me speak to Fibaro" for Fibaro units as it's fully supported, same with other hubs that are fully compatible with Google Home. It's only on something like Homey you need to "tell homey" as it's still not fully supported via Google Home. Once Homey manage to negotiate with Google for full support, all you need to do is say "Hey google, switch off lights" instead of ask homey.
Vulpix
Moderator
Moderator
Your best bet is to wait for Homey to gain full Home support. Wait for Athom to negotiate finish with Google, because right now to activate Homey it's super clunky, but Homey is one of the few hubs that support almost everything, even ZigBee and Z-Wave. That said, there are some glaring issues with the Homey, here's a video that highlights them:
xingkia
Hi everyone, anyone tried turning on a mitv or mibox using Google home? As the mitv/mibox uses bluetooth remote to turn on, those ir hub wont work on them. Thanks!
Vulpix
Moderator
Moderator
Anyone has recommendation for Zigbee or Z-Wave light switches? Is the Xiaomi Aqara stable? Looking to get a Hubitat.
xingkia
Bullfrog using it since last yr June/July. So far he say no problem la. Will most likely go for the xiaomi smart switches as well.
Vulpix
Moderator
Moderator
Ah ok. So far I read Aqara drivers for Hubitat is developed by a user for Hubitat, so I'm kinda worried it might not work well with Hubitat.
bullfrog
I'm using aqara switches and xiaomi gateway to work with Home Assistant. However, the latest firmware update for xiaomi gateway disables the developer mode access which HA needs. I didn't update so it still works. However for those that did, it seems to have broken HA. Don't believe there is a way to roll back either.
Posted from PCWX using Me dic stinks
Vulpix
Moderator
Moderator
Damn ok. I don't intend to use the gateway as I read Hubitat can interface with it directly via Zigbee. It's really hard to find 220v light switches with Zigbee, I find on amazon UK and it's mostly Aqara ones.
gheesung
May I know which version of the gateway disables the developer mode access? I have upgraded mine and it seems that I am still able to get the network key and communicate with other xiaomi sensors/switches.
bullfrog
Vulpix
Moderator
Moderator
Anyone ever tried out this brand called TKB? They are one of the few China companies that have Z-Wave Plus certification.
lamtw22
Can the Xiaomi Yeelight Smart Bulb v2 be setup in Mi Home app (SG Server) or must use Yeelight App instead ?
ksw101
Hi, are there any devices to turn on/off aircon with multiple schedules? I want to set this to my kid room over the night.
