Just bought my Redmi 7 global set
3G/32GB for 165
Wonder local retail how much
deciding between redmi7 vs pocophone and the A series...
any comment on this especially redmi7 vs poco?
What is the cheapest globar rom export set at the moment? Need it for my parent. Maybe buy 3gb+32gb version should be enough.
Sent from Xiaomi MI MIX 2S using GAGT
From which online seller? Thankscheapest I dun noe but saw these...
2GB RAM / 16GB Internal Memory - $138
3GB RAM / 32GB Internal Memory - $158
3GB RAM / 64GB Internal Memory - $178
Thanks, will do research again tomorrow. Considering this phone or note 7. Maybe note 7 is easier to read for parent. Export set with global rom is fine.carousell
officialstore (this is not xiaomi official store...)
do your own homework b4 buying... not responsible for anything...![]()
Is this phone able to support tpg?
I see. So note series is using hybrid sim tray.Redmi 7 have 2 sim slot and a sd card slot Redmi Note 7 don’t have this do take note
So with the extra slot I can put 2 SIM card and a as card in instead of one sim one as card for note 7
The resolution on this entry lvl phone seems very low. Anyone feel the same way?
