soCash
Wingst
Hi the store code must find stores that has the code? Or any store?
And I should choose to use store code or the referral code? As both is $3?
peppermint7
only certain store has code. a day ago i went harbour front. the store there has got $3 store code. if u pass by there can try. for first timer only.
referral code is on top of store code
addict951
High Honorary Member
eh guys, where can I find my referral code in the app? Cannot find leh
Nao got promo if you refer someone and that someone makes a cash withdrawal, bof will get cash.
NTTDoCoMo
For referral code, click on the top left hamburger menu and select invite friends.
addict951
There's no code right? You have to 'refer a friend now' either via sms or whatsapp, then your fren click on the link and sign up?
I dun see any referral code anywhere
NTTDoCoMo
There is a code beside the Share button.
Maybe you check if there is any updates for the app?
addict951
****h, must always update app to see latest promo
Now I see the code liao
Old app version is different. Wasted my 1 lumber :vijayadmin:
NTTDoCoMo
I think they upgraded the referral code system, I refer my friend he withdraw same day but I never receive any referral fee. I whatsapp socash support and they ask for evidence to manually key in the Referral Fee.
addict951
After you earned the freecash, can it be freely transferred to anyone ar? :o
I read some of the previous posts riao
Seems like you need to keep performing transactions to tap the free cash? :o
Thanks for all your replies, NTTDoCoMo. :thumbs up:
NTTDoCoMo
Cannot transfer out. FreeCash only use to offset next withdrawal.
addict951
Another kwestion: my nearest socash store has a promotion icon on it. Usually means got more free cash?
