Redmi 7
K202020K
Better use our thread
Later people not happy
Give us free NTUC Link points
Sorry bros
amazingone
https://www.facebook.com/XiaomiSingapore/photos/a.642763505764754/2637690026272082/?type=3&__xts__%5B0%5D=68.ARChTLCgS-r7El6W8uN95br3Qbba7kWVC5oPVwibl9k9wjcEOs0SYRChYxqdtcxb7m8wG4edsRoj7g9Sb2Ewh52l9IheqmXUzR4pEPHrHgGJrxdwSI4QbloiBmPL__1sFeN9uTwcs2RjGH0jpPDRVACgYn_-eYtUsGTbDAyRaSGpgsdkD3ydnzRkyGDCDBmOAT5XBZxf-F7i4fyIdwuTQF36spwgx2WzIiVx4nRAp9Gfjdzm8yj1NKYy_usnAbI_dPa5FAgH_zdfT0xgnpL_EV-NPomCLovRdlh4ut2U5-kWn6k3DfHuA-XPe0JuGGr_BqUj0frPxxOAPiRYa7jKeFjWqA&__tn__=-R
ongware
deciding between redmi7 vs pocophone and the A series...
any comment on this especially redmi7 vs poco?
carboy00
Redmi 7 and Pocophone are in 2 totally different segments altogether. Pocophone has significantly better specs all round because it is marketed as bringing flagship specs to mid-tier price. Redmi 7 on the other hand is in the low-end budget segment.
No contest here, if your budget can stretch for Pocophone, go for it. I don't think the prices of Redmi 7 and Pocophone are close either.
Sent from Xiaomi Redmi 5 using GAGT
ceestudent
What is the cheapest globar rom export set at the moment? Need it for my parent. Maybe buy 3gb+32gb version should be enough.
Sent from Xiaomi MI MIX 2S using GAGT
eriol125
Went Bedok Mi store ytd . 16GB only got black, 32GB got blue.. but i wanted Red. Haiz...
Sent from HUAWEI VOG-L29 using GAGT
ahwei91
cheapest I dun noe but saw these...
2GB RAM / 16GB Internal Memory - $138
3GB RAM / 32GB Internal Memory - $158
3GB RAM / 64GB Internal Memory - $178
ceestudent
From which online seller? Thanks
ahwei91
carousell
officialstore (this is not xiaomi official store...)
do your own homework b4 buying... not responsible for anything... :)
ceestudent
carousell
Thanks, will do research again tomorrow. Considering this phone or note 7. Maybe note 7 is easier to read for parent. Export set with global rom is fine.
Is this phone able to support tpg?
ahwei91
yes, according to someone in tpg thread, both 7 and note 7 can support tpg...
you can go and double confirm in tpg thread... :)
foxer77
Redmi 7 have 2 sim slot and a sd card slot Redmi Note 7 don’t have this do take note
So with the extra slot I can put 2 SIM card and a as card in instead of one sim one as card for note 7
ceestudent
I see. So note series is using hybrid sim tray.
Does redmi 6 also support 2 sim + micro sd as well? Anyway, considering the price at the moment better to get redmi 7 than 6.
tellim
Brought one as spare phone to play mobile legend. No issue running it
