Redmi 7
K202020K
But pity abt local sets for realme 3 is that it is all 3/32GB instead of the 4/64GB variant. Perhaps that's why can sell under $180 wif 2 year warranty.
Not too bad lah
It's an acceptable & affordable package for budget phone buyers
Especially with a dedicated microSD card slot combined with two separate SIM card slots
The negatives are :
No LED notification light
No Wi-Fi ac
No NFC
No gyroscope
No IR blaster
ceestudent
Not too bad lah
The negatives are :
No Wi-Fi ac
No NFC
No gyroscope
No IR blaster
Any dual apps like miui? I use dual whatsapp on miui for 2 simcard
K202020K
I know Color OS has such a dual apps feature called Clone Apps ....
But certain models like the Realme C1 don't have this feature incorporated in the system software
However there are workarounds for this issue
If I'm not mistaken, the original version of Realme C1 with Color OS 5.1 has this feature incorporated
Not sure for the latest Color OS 6 running Android Pie
DarthGW
any online stores selling redmi 7 cases? cant seem to find any
kazuki666
What's the cheapest model I can get for RM7 now? Thinking to get one for my mum. She is using my really really old RM1...
Sent from Xiaomi POCOPHONE F1 using GAGT
ceestudent
From Qoo10 seller jtbc (listed as 199$). Use 30 off 200 coupon combine with qpoint, gift card rebate, cc rebate, and shop back. Should be around 170$ for 3/32gb with local warranty. Somehow other seller that selling below 190$ cannot use coupon one.
foxer77
if u want cheap go for newstar electronic Qoo10 3/32gb with 1 month warrenty ~ $159 global rom
K202020K
Redmi 7 3GB/32GB local warranty set is now available for $170 with one year local warranty support.
Wonder if it comes with a polymer protective bumper case included in the box.
Good buy except don't have Corning gorilla glass protection which is very important for some users who like to scratch the LCD screen with hard objects.
K202020K
Why no Redmi 7 selfie edition?
No successor to the Redmi S2 after such a long break? Quite funny, and incompetent too. Maybe it's because they already killed off Asus budget line, can afford to take a long break.
amazingone
There's the Redmi Y3 in India, which essentially is the successor to the Redmi S2.
Specs and design are identical to Redmi 7, but with a 32MP front camera.
K202020K
Thanks bro. But I'm not an Indian and they have the misconception that only in India do the people take selfies yo.
Rav_05
I wanted to buy a cheap spare phone. Am thinking either RM 7 or Ulefone Note 7p (Usd 89).
matrix05
Udimigi A5Pro (P23) and Ulefone 7p (A22) are the 2 that can fight with RM7; on price, giving more RAM. Their SoC is no fight with the SD on RM7 but if you don play FPS games, it less of an issue. However, stability & reliability are also unknown. RM products are of certain quality.
ofc there is a RM7A.
Sausage
I have an odd problem with my redmi 7. After charging to 100% and unplugging,it remains at 100%. Only after I reboot do I get the correct battery level shown.anyone encountered this? Using global 10.3.1.0
Sent from Xiaomi REDMI 7 using GAGT
K202020K
Go to play store and download app that can do battery calibration, may be helpful in your case. The battery may be faulty too. 小米 phones, the battery is under warranty for 6 months, not one year. So, they can get away with using poor quality, cheapo batteries in their products.
