Huawei Mate 10
Ruriel
My NFC suddenly not working properly .... I tried to tap for Google pay but cannot detect.
However, it can detect my ezlink , just not payment terminal
If can detect ezlink means the NFC function should still be working. Is it you didn't place it well at the payment terminal? Iirc the NFC chip is above the camera lens...
There's one payment terminal that I have difficulty with when trying to pay with mobile GPay though - which is at breadtalk. For some reason those type (super small and under UOB) are unable to detect the NFC on my phone. Had to use physical card for paywave. I have no issues with other payment terminals though.
CS0287
I tried for MRT gantry, didn't work... Not sure if it's Google pay issue or os issue.
Breadtalk not working for me as well...
Maybe I will try 7-11 later.
JT2008
Are you using NFC SIM? My experiences are the SIM card is conflicting with GPay for those terminals that are accepting both Ezlink and paywave contactless payment.
Try puting the sim card to slot 2 and test.
Soulfly
Thanks for the reply guys. My battery is not bloated. And I've never overcharged it before. Suddenly, it gets very hot and it cannot hold charge and will switch off after it reaches 40%. My phone is still under warranty, I hope Huawei service centre will change the battery...
CS0287
I am using normal sim card.. no NFC .....
Just tried with food republic paywave .... Not working.. no response, as if like the phone not detecting anything .... This is so frustrating
Anyone having similar issue ?
JT2008
Did you check is NFC default payment defaulted to GPay?
Ruriel
Is your phone turned on? When did this problem start? Previously no issue? You have to trace back to when the problem started - see if anything has been updated or installed that is causing some conflict in your phone.
CS0287
Yes it's set to Gpay
Turned on and looking at the screen, then tap the terminal, nothing happens...
Not sure when it happens , my last transaction was 10 May..
The only suspicious issue is Gpay updated 2 days ago..
Ruriel
I have updated my Gpay to the latest version when the update was released, and it was fine on my phone. You wanna try to reinstalling the app? Sometimes something in the backend might be botched during installation of updates...
CS0287
Tried reinstalling, clear data, clear partition cache , Google play services data... And still not detecting MRT gantry.. :mad:
amazingone
Waiting for EMUI 9.1 to be pushed to global Mate 10 :o
Posted from PCWX using HUAWEI ALPS
donetus
it was said that existing phones will not be affected . however i'm not sure how they define "existing" phones because P30, P30 Pro, Mate 20 Pro already existed prior to the ban ..
I was also thinking of the same thing, changing the phone that is, but it's still eary to do that though . hahaha.
So Mate 10 still ok atm as the mentioned phones are P30, P30 Pro, Mate 20 Pro. Time to change phone :s11: :(
OutBreak
Better move your data to non-Google apps asap.
I have disabled Chrome and use Firefox and DuckDuckGo search engine. :D
Go **** yourself Giggle!
amazingone
Very hard for me, I'm already reliant on Google for my internet stuff like Drive, Photos, YouTube, Gmail etc.
