MacBook Pro accessories
discoburg
Any good accessories to recommend? Looking to buy a clear and thin case for the MBP 13" and also a clear keyboard protector.
Proximus
Am not using any case as they make the macbook thick.
Bought and applied the dbrand black dragon skin.
As for keyboard protector, i got the cheaper version from taobao as premium brands like moshi turns milky after some time too. So why pay for 3 to 4 times the price....
discoburg
Need to ‘protect’ as mine always have scratches all over. Agrees with not paying more for branded covers which will turn cloudy fast.
*adiBOY
Just get a carrying case will do. You don’t need a housing to protect all over.
Good recommendation will be incase taserlite carrying case.
discoburg
I usually stack things on top and below the Mac when carrying around in the house.
Snoweagle
I'm still using my 2015 model. Screen protector pasted since day 1 and keyboard protector replaced last year (clear silicone one from taobao) and Herschel carrying case.
Honestly I find screen protector not exactly necessary as unless you're afraid your Macbook is affected by staingate. Keyboard protector a simple one, but more importantly is a carrying case or a sleeve.
discoburg
Used to own a MBP Retina display and the screen is stained AF and I couldn't sell it off for a good price. After that I began to apply screen protectors for my 12" MacBook and now this 13" MBP.
Looking to get a clear keyboard protector now. Can't remember where I bought my 12" MB one from. It is of good quality.
*adiBOY
The new MBP with butterfly keycaps won't experience any stains so don't worry about it.
Else, you can buy the keyboard cloth from Radtech for an additional layer of protection.
discoburg
Good suggestion.
dreamer_toons
The radtech can be used to clean the screen too.
Too bad, it only cover the keyboard area now; the cloth was used to be big enough to cover the keyboard and the trackpad.
Snoweagle
I applied too because of this issue, but my next one maybe won't already. Planning to upgrade next year.
discoburg
The larger version for the older MBP is still available in their online stores leh. You think can fit into the current MBP. 😅
ralliart12
Where’s a good place to get the 3M privacy screen protector (gold) for the macbook pro, if I may ask?
