The Spectacles Thread. - Part 2
SquallLH
Fake lar.. Me photoshopped one..
I thought my math is bad but it seems the site has worse subtraction ability with $123 - $12.3 = $90.7
Zonker
For Digital lens and energizeme, both comes with blueprotect. Transition/photofusion is an add-on for you to decide!(Cost)
Hi I’m looking for digital lens. my degree is -2.75 both side and cyl is -0.5 & -0.25. Can u pm me the price n range of digital lens pls? Closing in age 40 soon.
Thanks.
Nakedtoes
It's actually $32.30 discount. Lol.. 90.70 with frame and free 1.61 lenses I cannot ask for more..
thegardens3b
Thanks.
I feel you MIGHT be better off with progressive lenses... Will last you for a longer time ..
GANGSTERKIA
Progressive is another option. It depends on each individual progression of presbyopia power. At such an early age from 37-40 it (presbyopia power) should increase at a steady pace thus if you don’t mind paying more to use a progressive lens then by all means.
Adaptation is harder as compared to a digital lens but if you can adapt to it well then it be perfect. At that age group also your presbyopia power should fall around +1.00-+1.25 which fits the digital lens category so you can consider between a Long term benefit or a mid-term benefit.
Nakedtoes
Bro usually around what age then the progressive power will be stable? else every year the power getting worse need to make again
GANGSTERKIA
Based on what I see. Most get stable around 50 onwards! Usually in the range of(Lao Hua/presbyopia) +2.00-+2.50(average) sometimes even higher.
jonathanljk
Specs broke so gonna have to make a new pair. Previous pair was crizal prevencia lens is that still a respectable tier of lens? Totally lost with all the different types. The crizal lens seem to attract dirt easily so was wondering if any other lens will be recommended instead. Thanks in advance!
thegardens3b
Yeah, pretty decent. Sometimes, if the lenses are still in good condition, can find a frame of similar design to try to fit the lenses in to salvage the lenses. :)
I wouldn't say attract dust... All stuff will have dust on it.. Kind of inevitable. If you are happy with prevencia can stick with it. If not can upgrade to other brands e.g zeiss/hoya blue protect/control
jonathanljk
It’s been almost 2 years so might as well take the opportunity to try other style of frames as well :D so Hoya blue control = crizal prevencia? Would like to try another brand of lens this time round
thegardens3b
yup you can say so. work by reflecting blue light away from the lenses :) good luck on getting a new style of frame ;):s13::s12:
sky00sky
Thats an awesome lobang tbh. Even cheaper than cost price!!:eek::eek:
To be fair, it might be overseas or PI .
Cos the cost of doing business locally is pretty steep and the overheads /AnP of the "brand owners" are slapped into all the products sold locally.
