Oneplus 7!
Extolbeli
Sorry typo, I can't get back my coupon.
No choice, will wait item to restock. That's the only option that I have.
Oh wait, so they just told you no stock but did not cancel your order?
Then I think you should just wait till they restock and send to you.
oprahsbs
It's very quick. Cos it happened to me.
Bought from Simder trading using qcoins. Went to their shop and told me no stock.
Called qoo10 and they refunded the qcoins within minutes. Then I bought from another qoo10 seller that also had a shop in sim lim. picked up my phone immediately
Bro did you get your coupon back? Pls advice me. Need to make decisions latest by tomorrow.
TIA!
DailyRoutine
TIA!
I bought with qcoins, didn't use coupon.
But iirc normally coupons are not returned. Need to confirm with other bros here, I could be mistaken
cosycatus
Amex just have new promotion. Buy qoocoins with 15% off. I just purchased 6gb +128gb set for $744 with $120 coupon.
Sorry..very noob here, how to use q coins and the voucher? I try to buy in the quubee app don't have voucher option
Extolbeli
Yes, dont use qubee to buy. Normal qoo10 check out can use qcoin as payment options. If you buying from w digital, remember collect their $20 store voucher. Ytd I never see, forgot to take. Can stack with 120coupon making it 140 discount.
cosycatus
Aiseh. Thanks!
We can't buy the exact number of coins right? So will be left over?
Planning to get the 256gig, add 50 more ( or 70 dollars more expensive Nia)
pspcrazy
Local service center location has been announced - OnePlus authorised service partner : Mister Mobile (City Plaza) 810 Geylang Road #01-67A located behind the taxi stand,facing Kinex Mall Opening Hours:11am-9pm last appointment 8pm (take note their OnePlus service warranty repair is by appointment only)But is good as they take in export set for repairs too
leaving_footsteps
After using OnePlus 7 Pro, I find the fingerprint scanner irritating. Failed to unlock most of the times.
And also, VoLTE doesn't seem to be working (as usual). Probably need some hack.
Any ideas?
Extolbeli
Aiseh. Thanks!
You using Amex? Amex have to buy in 100s. Then remaining you just buy individual qcoins without promotion. That's for my purchase. But now with 20bucks voucher must recalculate see buy what type more wuhua.
leo0o0
Where did you see the 20 bucks voucher?
absolut777
Suspended
Any ideas?
Fingerprint will improve over time as you use. Initial set up must have it capture all areas of finger, even the sides.
AFAIK volte is turn on by Telco for device? There's hacks but involved rooting and stuff that I'm past bothering about.
