home karaoke
ksapple
Hey, can ask the karaoke box from taobao,
any auto update of songs?
is the song list complete for most chinese songs?
mainly singing taiwan and china songs only..
No auto update, u need to update urself it gt a internal update program, i update it every 6 months or when i feel like it.
Gt all latest Chinese song
deadrick
Thank you, update manually is small issue as long as easy to do so with some update function.
I see the link, there are 2 version, what's the diff? The black and white one. White one more exp, 1260rmb for 2tb, black is 1060rmb for 2tb.
Actually 200plus not exp compare to what shop are selling at ard $1k.
ksapple
now sooo cheap i buy tat time RMB1460 T.T for 2 TB. Want to DIY upgrade ssd but scare haha
deadrick
Which one did you buy? The black or white?
Interface easy to use?anywhere I can find people using like video or youtube
GreenArrow2002
Bro, can show me the link for the item you puchased? I am looking for such a system for my wife who is now karoke crazy :D
Is the setup complicated for a layman?
Thanks
deadrick
BTW what is the HD for? When u select a MV, to play the MV it has to be downloaded to the HD?
It's not via streaming?
souleclipse
aristein
Hi Need help from popsical Remix user here.
My Sony Soundbar is connected to my TV HDMI IN (eARC/ARC) so that all Audio will come out from the Soundbar and not from TV
The popsical is connected to TV-HDMI One
Popsical 3.5mm cable is connected to Soundbar ANALOG IN.
When songs are played, there is video and sound, but just no sound coming from the Mic.
The sales rep asked me to switch my SoundBar setting to Analog, after switching to Analog, the mic has sound, but TV has no video, just blank screen with music coming from the soundbar.
there should not any problem with both my tv and sound bar as everything works fine except mic has not sound. their product specialist is unable to help. Dun know what went wrong.
Help needed
GreenArrow2002
Just gotten mine, bought a 3tb one.
Makes singing so much enjoying than using pc free karaoke software..
How to manually add mtv ar? There are a small amount of songs I can't find.
Then then most songs are already uploaded right? How to do the manual updates of songs?
How much you pay for the 3T version? Is the setup easy for novice. I'm looking for such a system.
SyncGuy
Help needed
I think because you're forgetting to plug in Popsical Remix into TV HDMI..
eARC/ARC is not supposed to be in the equation here..
Basically,
Popsical <- (HDMI) -> TV
Popsical <- (Aux) -> soundbar
1) Set TV input to HDMI 1/2/3, whichever that is NOT the ARC port, for video
2) Then set Soundbar input to Aux, for sound
3) Enjoy...
circles_tao
Hi, anyone has feedback on the image quality of Popsical on slightly larger TV screens? Am wondering if image quality would be poor on a 65 inch samsung qled. Thanks!
xuan87
anyone has recommendation for karaoke mixer that can support 4 wireless UHF microphones?
I know most support 2 wireless + 1 wired microphones, and I've seen a couple of models that support 4 wireless but unsure of how good is the quality.
if anyone has a model to recommend, that will be great appreciated!
Samuel_LKH
Help needed
HDMI need to connect directly to Tv for Visual. Cannot go through soundbar as a medium.
Aux need to go directly to soundbar. Aux is for mic.
tkdboi
I am using it on my 55 oled. no issues from what I can dee
Sent from Samsung SM-G975F using GAGT
