Nakedtoes
- Dec 9, 2002
Sure.
I suggest you do whatever system updates you want first as those will undo the VoLTE "fix" though (I had to redo it after updating to 9.5.7).
- Go to your dialer and enter *#800#
- Click enter > oneplus logkit -> function switch -> enable volte switch and vowifi switch
- If you don't see those checkboxes, update the Logkit using the APK from https://forum.xda-developers.com/showpost.php?p=79577939&postcount=23 and do the above steps.
You need a PC for this part. Go to https://forum.xda-developers.com/oneplus-7-pro/help/force-enable-volte-vowifi-t3934227 and follow the instructions. But basically..
- Download and install the linked QPST thing then download and install the driver.
- Go to the dialer and enter *#801#. Turn on Serial and Full-Port.
- Connect phone to PC.
- On your PC, go to Start -> QPST -> and run the PDC program in Admin mode.
- In the PDC program, click the Device dropdown (yes, the UI is awful) and select the thing there.
- Look for "Oversea-Commercial_DS", right-click on it -> Deactivate -> Sub0 and Sub1
- Click on "Oversea-Commercial_DS" again and click the remove button.
- Restart the PDC program and select your device again.
- Pick "India-VoLTE-Vodafone", right-click -> SetSelectedConfig -> Sub0 and Sub1
- Click on "India-VoLTE-Vodafone" and click the activate button.
- Restart your phone! You can now disable the Serial/Full-Port things.
- Go to Settings -> Wifi & Internet -> SIM & Network -> SIM1/2 -> Enable the VoLTE things there too.
Wah so troublesome.. Why default no volte? What the **** oneplus doing?
maybe i just forgo tapping on volte until tpg adds this to their network nx time since can connect to 4g data to use first. just that i'm not sure if will jump ship to tpg if their plan is attractive enough
