Oneplus 7!
watzup_ken
Please don't compare pocophone with OnePlus leh. Extremely degrading. MIUI + shitty IPS panel.
Who wants IPS in 2019? Even my house TV already OLED
Sent from OnePlus GM1910 using GAGT
I actually thought the IPS on the Pocophone is quite decent. While of course it cannot compare to the likes of the OnePlus 7 Pro, but the Pocophone cost less than half of it. If money is not a problem, OLED screens will be good, but they are not without their own problems.
watzup_ken
Actually Is there any other reason to buy the local set from Lazada other than the 12 months warranty? Or otherwise can I confirm the export set on Qoo10 can have the regular updates as well?
To be honest, no different from my opinion. While you get local warranty for the local sets, there is only 1 service center in SG which just started. The local sets are also quite expensive (based on pricing on Lazada official store) as compared to the export sets.
anthonygreenisreal
Yeah man, it’s more expensive by a large difference. I think it might even be cheaper than the price difference to have the phone fixed out of warranty.
Nakedtoes
I comparing the faceunlock function.. Yr Brain got problem?
anthonygreenisreal
Okie I got the supcase unicorn beetle and it is able to fit. All the ports and cutouts fits perfectly. It is supposed to be for Op6T I guess. So guys, I think we might be able to use the 6T case for OP7. Disclaimer, please try the case first.
Nakedtoes
Bro calm down. Chill. OnePlus 7 notch smaller than Poco. Likely faceunlock function Poco better.
Yeah.. poco advantage is the extra infra red camera.. I started to appreciate this function although i still dun like the notch.
I am thinking OP7 vs redmi k20pro.. since i think both price is abt the same.. but still OP7 advantages is the UFS3.1 but k20 pro is the notchless looks, 3 camera bs 2 cameras.. going to go for k20 pro.
leowweiqi
But k20 pro is China ROM?din heard any mi 9t pro announcement
WhiteAnt
K20pro also got infrared camera?
