OCBC Titanium Mastercard
bluecrab
Does purchase made at Samsung Experience Store get 10x?
Sent from Samsung SM-G973F using GAGT
qwazimodo
Hi,
Can I check if purchases from Skechers in Melaka is eligible for 10X OCBC$?
Thanks!
Regards,
Ian
Contactsourav
Hello,
Does the Prada store qualify for 10X miles?
Also does the Frank Muller store qualify for 10X miles?
Finally does Sincere and Hour Glass also qualify?
Thanks!
OCBC Bank
Suspended
Hello,
Thanks!
Hi there,
Prada will be eligible for 10X OCBC$.
Frank Muller, Sincere, and Hour Glass are not eligible for 10X OCBC$. Watch retailers does not fall under the eligible categories.
^DG
kashanai
Can’t find any thread so would like to ask OCBC when will the rebate for MasterCard SimplyGo be credited to credit card?
Terms and conditions states end May if I’m not wrong
Thanks
OCBC Bank
Suspended
Thanks
Hi there,
Due to an overwhelming response to the promotion, we are currently checking on the qualification status of all the registrants. Please be assured that if you have successfully registered, you will definitely be eligible for the Rebate if you had spent on Bus/MRT.
We are working to credit the Rebates as early as possible. While we ask for your patience till end July, we expect to resolve this within the next 5-10 days.
^DG
kashanai
Thanks for the update
Maybe then ocbc should do a sms to update those who are eligible on the delay?
Hi there,
^DG
OCBC Bank
Suspended
Hi there,
Thank you for the feedback.
We’re still running checks on the qualification status of all of the registrants, hence we aren’t ready yet to inform customers on their status.
^DG
OCBC Bank
Suspended
Hi, i was not awarded 10× OCBC$ for some of the above transactions which were made. Please assist to check.
Hi there,
Please drop us a PM with your bank registered mobile number. We will call and help you sort this out.
^DG
dogma69
Hi OCBC
I applied this card during OCBC promo whereby you can get 32000 OCBC$ when you met 2 requirements
1) Get 21500 OCBC$ upon card approval. My card was being approved in May and I should get 21500 OCBC$ by 30th Jun
2) Get 10500 OCBC$ when you make a qualifying spend of $300 within the first month of card approval. I’ve made a purchased of more than $300(Courts) in May and I should get the 10500 OCBC$ by 30th Jun
I’ve since received the 21500 OCBC$. So now the question is, it is already the 3rd Jul and I still have yet to receive the 10500 OCBC$. Why was it not being credited? Appreciate your kind reply. Thanks
