Oneplus 7!
eddy0505
Haha. Bro.. Her other areas are deep as well.
Maybe as a tech person myself. I pretty much enjoy his videos. Easily understandable.
Will give them a try. Thanks for the recommendation
Sent from OnePlus GM1910 using GAGT
Just watched mkhd's review on oneplus 7 pro to see how "shallow" his reviews are. Imho he didn't really test drive the phone/using it as his daily driver as whatever info shared in his video are pretty much available on the internet. expected more from someone who has 8+mil followers. Just my 2 cents.
mahcosg
Looks like battery life is very decent on 90hz, qhd. Love this phone so much
GreenHorn
Ya no point reduce to FHD ... Just use what it's capable of. With warp charger in my car, I never worry about battery life.
Sent from OnePlus GM1913 using GAGT
GreenHorn
His revenue is to high to consider going in-depth into the phones
technolust
Guys , want your opinions . How is the op7p compare to the op7? Camera , battery life and performance wise. Also I see the pricing is quite crazy for local sets. Will it make more sense to go for import sets? Thanks in advance :)
GreenHorn
I think most people here go for export sets.... For me, I go for local set due to resale value and peace of mind.
If u not going to change phone often, should go get export sets
technolust
Yeah his reviews are too glossy and bite sized for easy consumption for the masses. It's hard to go in depth and do a rigorous and proper presentation and review when you are targeting the masses. He also plays" safe" as he cannot offend the big manufacturers and the masses that buy those products. He is very commercially savvy in that sense but not the right reviewer for techies imo who have higher expectations. I would recommend Juan bagnell and flossy carter for pretty good reviews. Micheal fisher is not bad also but less technical and in-depth
rootz
Bro, most would go for export sets due to price. As for Warrenty, typically oneplus does last well for the Warrenty period.
mahcosg
I find the non pro not appealing. No wide lens and just another typical phone
anthonygreenisreal
The appeal of the non-pro is not to be appealing. Just a reliable everyday workhorse with no nonsense top notch smooth performance. No curve screen, no mechanical pop out camera for you to worry about damaging.
Mclairs83
If you are using P30 Pro. why make the switch?
If you want battery life, just stick to P30 Pro
If you want camera, stick to P30 Pro
you want performance? go for OP7 Pro.
SD --> Kirin --> Exynos --> MTK.
Is there any difference between local and export set? The Rom?
this has been answered don't know how many donkey times.
Local = more LTE bands, warranty coverage by local disti
Export set = flash with OxygenOS, no warranty not as much LTE bands as local set.
if you use it locally, no impact at all.
mahcosg
5h sot with 33% left. Qhd , 90hz. Guess this sot good enough for one day of daily usage. I will stick to this configuration.
niwde1980
got shop sell local sets ?
technolust
Thanks bro
Yeah that's what I thinking too. P30p is real flagship while op7p is ex flagship killer, more like wannabe flagship now . Lol
Just itchy want to try the software. Are there any interesting features of oxygen os on android p that is unique to the op7p only?
watzup_ken
Agree. P30 Pro is still a great phone to me. Only thing that I don't really like is the EMUI which is very clunky and very aggressive in killing idle applications.
Performance wise I think unless you game, you probably won't feel the difference between SD and Kirin. The SD 855 is better when it comes to GPU, thus, giving it a performance edge.
