The Spectacles Thread. - Part 2
shawn_sboi
I'm about to go there make lens too, his price quite good
Posted from PCWX using FCS, Asia No.1 Pro Trader (FCS是,大中华,香港,日本, 南韩投资行业的赫赫知名人物! )
His price compared to Eyecon are they similar? Thanks!
ahger_2311
Have you went back to double check with your practitioner for adjustments?
Lifting to see bottom of the lens at distance clearer? Or towards intermediate?
Haven went back to optical shop yet cuz busy sia.. I collected on Thursday only. And I only notice the diff when looking at presentation slides..
Top part is most blur, middle part less blur, bottom is crystal clear.. and I notice it’s more obvious (in terms of diff) on left eye..
GANGSTERKIA
My suggestion is to go back to inform them so they can make the necessary changes if needed.
ahger_2311
Is there a deadline to go back?
Like 3 days or 7 days? Cuz the earliest I can go back is next Saturday sia
Probably good to go back and have your degree checked again. :s13:
if you see clearer at distance using the lower portion (lower degree), chances are the distance might be over corrected
s3856
Hi guys! I’m looking to change my lens on my glasses. Any places to recommend? Kept reading that going to JB is cheaper.
What’s the price right now for Hoya transition + blue filter and just blue filter lens?
You may try Pro Eye Studio @ Paradigm Mall JB. They having promotions now.if buy one ic!Berlin frame is 30% discount and second frame for 50% discount. Offer end at Jul.
shawn_sboi
Thanks bro! i love ic berlin! i have 3 pairs from them! thank you! but i have 2 other frame i would like to do. I will head there on the weekend to see. Thanks man!
shawn_sboi
Read on Facebook the review not very good but it's other branch. I will go there to enquiry still and check. Thanks!
GANGSTERKIA
tortoise18
Crizal Prevencia & Zeiss BlueProtect uses a Blue Coating to reflect blue Light. These lenses usually appear much more yellowish than normal.
Kodak UVblue has HEV(Blue) Filter properties inbuilt into the material, this lens will have a more natural view.
Ah.. I asked Taeng, showed him my specs but he said no blue filter 😂. Then i should just stick to kodak next time lol
gerald91
need some advice here..
i always have the perception that transitional lenses are only worn by uncles and aunties but recently seen a few younger adults pulling it off too.
any recommendation on what kind of frame is best suited for transitional lens?
currently, i am considering the rayban wayfarer type of frame.
GANGSTERKIA
Depending on your degree, I recommend Using clear transparent frame. In trend right now. Can be doubled up as a sunglasses when outside.
Or if you daring enough, go for double bar. Very popular in Europe but in sg... still conservative.
gerald91
double bar like the aviator ? i tried aviator but cannot pull off (face too fat/big. hahahha)
ok will go check out transparent frame.
Tks man!
5adisticD3vil
this is a long shot but anyone know if here local got sell this or similar ?
only manage to find it in rosemanclub in thailand
can buy online but still wanna see can get local or not
frame only... need to do the lens here
LaksaTitan
Raybans nose pad turning green. Does my optical shop have original stock or do I have to go to service centre to get them replaced?
Sent from OnePlus GM1910 using GAGT
