Oneplus 7!
shawniiex
anyone tried simplygo on OP7?
if it works with the screen off, could someone try their dash pay (should be can) /google pay (i think cant)?
WhiteAnt
i can confirm google pay via mrt ezlink payment must turn on the screen. if anyone knows how to make the option to use at mrt without waking the screen, pls share here thanks :o
dash not sure as i don't use that
haojie91
Gotten my OP7 pro from shopee. God the display is beautiful! Whats the recommended loca TG besided WSD?
Sent from HUAWEI CLT-L29 using GAGT
KeYoKe
Also from Mobile hardware. Around 30+. When my zeelot failed after 1 week. Screen cracked although I didn't subject it to any hard impact, I replaced it with the Classy. Ok for the price lah.
I personally don't find zeelot durable.
clasy coating not as good also... best bet is still whitestone ba, else if ok with plastic protector just use the factory installed protector
KeYoKe
Oh ok, i guess i shall widen my search for other tg. For non loca, how's spigen?
other brands are just side adhesive, and side adhesive usually means the tempered glass will have micro dots on the screen, and there will be rainbow effect at random places
Dot Matrix:
Rainbow effect:
if u mean the water based application one, there will be orange peel effect (look like the orange skin) which u will see some wrinkles on the film applied:
269767d1506509703t-considering-remvoing-my-screen-protector-76821520-870c-4133-af2b-2ee8b1b3434c.jpg
kashix
Dot Matrix:
Rainbow effect:
Personally, if got rainbow or orange peel. I will stick with the default plastic film sua. It’s just now worth it.
haojie91
Dot Matrix:
Rainbow effect:
Woah thanks for the detailed info! I guess i'll use the stock for now
KeYoKe
haojie91
+1 :s13::s13:
yes, but do note film based protector dont protect against drop ya, just protect against scratches
Haha alright! The price tag for WSD abit chor, wait for promo then hoot. Thanks again!
KeYoKe
get from qoo10, got coupons then hoot, sometimes can hit as low as 29-3x range
but to be honest la, u spend so much on a phone, whats another 49 dollars. my 2 cents
