The Spectacles Thread. - Part 2
Nakedtoes
I am searching for transition lens and wonder how essilor crizal transtion xtrative performance?
is transition lens can be make with high degree prescription?
How long can a transition lens last with proper care?
YouTube got video comparing..
h3r090
Hello, intend to get my eyes checked as I am having difficulty seeing from far.
Which is a better place to have my eyes checked? Ngee Ann Poly Optometry Centre or Singapore Poly Optometry Centre?
GANGSTERKIA
Both are equally fine. Just see which is more convenient for you!
It is a full comprehensive check so know that it will take longer than the usual eye tests in optical shops.
Taro Pie
Which is better for single vision stock lens?
:s11:
nulux ep 1.67 double aspheric
vs
nulux classic 1.74 aspheric
Posted from PCWX using Nachtsider, renowned Michelin balut inspector & Jollibee connoisseur
GANGSTERKIA
:s11:
vs
Depending on your Prescription and the Size of your frame. If based on lens type, Nulux Ep will be better.
LaksaTitan
Hmm
I believe this is the correct one
let me know which of our branches is the most convenient for you?
Blk 184 Toa Payoh Central #01-366 S(310184)
Blk 143 Teck Whye Lane #01-233 S(680143)
Blk 101 Yishun Ave 5 #01-97 S(760101)
Blk 213 Bedok Central #01-127 S(460213)
Blk 301 Woodlands St 31 #01-259 S(730301)
I can arrange to have it sent there. You can just drop by and my staff will fix for you. No charges :s12:
Just replied to your PM.So sorry, didn't see your message
Sent from OnePlus GM1910 using GAGT
nikestar
Have been using many type of transition lens but i find hoya sentivity the best. Any idea where got good lobang for this?
Hoya coating i find the best against scratches!!
nikestar
Anyone knows where can i get hoya sentivity at good price? I find hoya quality is so much better compare to excellor and crizal
cmos196
calligraphy vs Asahi-lite progressive lenses?
Which one is a better choice? calligraphy or Asahi-lite
Was quoted calligraphy progressive lenses @390 (1.6?)
Any user of both brands here ?
Thank you!
Pocoyoz
Made a new pair of glasses yesterday but still having headache. Is it because of unequal increase in lenses powers. 0.75 D and 2 D. It's still under prescribed by about 1.25 D .:eek:
Sent from Amazon using GAGT
Taro Pie
How much do zeiss progressive lenses cost? :s11:
albino
Hi,
Can I know if I want to have Crizal Varilux® Airwear® progressive lenses for the condition of following eyes sight, may I know what is the price for the lense and a Titanium half frame spectacles.
Right eye
SPH distance +0.75
CYL distance -0.5
Axis distance 70°
VA distance 6/6
SPH Reading +2.75
CYL Reading -0.5
Axis Reading 70°
SPH Add +2.00
Left eye
SPH distance +0.75
CYL distance -0.25
Axis distance 100°
VA distance 6/6
SPH Reading +2.75
CYL Reading -0.25
Axis Reading 100°
SPH Add +2.00
PD 61
Hi,
Right eye
SPH distance +0.75
CYL distance -0.5
Axis distance 70°
VA distance 6/6
SPH Reading +2.75
CYL Reading -0.5
Axis Reading 70°
SPH Add +2.00
Left eye
SPH distance +0.75
CYL distance -0.25
Axis distance 100°
VA distance 6/6
SPH Reading +2.75
CYL Reading -0.25
Axis Reading 100°
SPH Add +2.00
PD 61
Airwear material (polycarbonate) has pretty poor optics, some wearers experience blurness even when using same degree after switching to airwear.
Unless really necessary or you're already on polycarbonate material, i wont suggest using this material.
Alternative impact resistance lenses would be Trivex (Impact resistance & superior optics)
https://www.allaboutvision.com/lenses/polycarb.htm
rayban
Hi want to find out something, will lens withstand extreme cold weather? Maybe -10-20 degree?
Currently what lens is recommended for Long usage of reading book and computer?
Shiro MS08th
Not following the prescription lens tech/innovation.
But what are the top tier lens maker/series recently?
I’ve been using Zeiss Single Vision Individual currently, one with blue protect, one without (using this only when editing photos or need color accuracy task). And also a Zeiss Digital on my old glasses.
GANGSTERKIA
From a neutral standpoint. Zeiss is still the best for single vision.
Hoya for progressives.
