Huawei Mate 20
hoks
Google pay and Simplygo. No error message. Just couldn't work. Used to be very sensitive even at a distance
Hi, anyone managed to get this working? Installed google pay, setup my card, enabled nfc, no issue. Tapped the phone at the gantry but nothing happen. Anything else I missed?
lwpro2
warranty start date
bought the mate 20 pro yesterday, however, just found out the warrant started two months ago. is that normal ?
1982-1994
hoks
Dis is is my setting, u mean need to disable 'make mobile payments and share files'?
yosemi
Anyone has issue with their huawei camera app , when taking picture it doesnt have the shutter effect, when i press the shutter button, it straight away take a picture without the screen blink/blackout .
I don know what is happening to my huawei phone, as google pixel has the blink effect when taking picture.
i tried downloaded other camera all is like that.
John_3330
Anyone facing random vibrations issue after the latest EMUI 9.1.0.300 update?
My stock Message app and Whatsapp keeps having "ghost" vibration when in fact there isn't and notifications at all.
It is driving me nuts!
Tried unstalling and reinstalling whatsapp, restarting phone countless times and other "fixes" from other forums doesn't help at all.
inviztj
Anybody knows where to get a charger for Mate 20 Pro? That can support it's SuperCharge functions.
I know the charger they provide is 40W, but there doesn't seem to be any 40W chargers out there. Would a say 18W charger still enable a 'weaker' version of SuperCharge?
sajokj
Mi have 45 w charger in market
maur_james
I had this problem with my email on the version before this, with the current version no more problem.
Hope you find a solution soon.
JT2008
Try disable Download Manager notification.. might help..
ApPle5
I disabled vibrations would that solve the problem or need to totally disable notifications?
Sent from HUAWEI LYA-L29 using GAGT
I disabled notifications. Lesser random vibrations but still there :(
Sent from 我是你的小呀小苹果。 using GAGT
laeticia
For mate 20 non pro full screen protector is it very difficult to find suitable casing?
Have to use those cases which do not cover much of the sides of the case. So the screen gets protected with the glass but the case can't have too high of side coverage
I use those cheapo China cases with back strap that's only $3+ and comes in many designs for ladies
Using Nillkin full screen glass protector + this case for Mate 20 and Mate 20X
https://shopee.sg/product/120932695/1943451626?smtt=0.0.9
