Recommend an airfryer
Kyo_kusanagi86
Philips Advance Collection XL Airfryer HD9240 i abused it 3 years and counting. no rust no nothing
using the same model here. The reason why it didn't rust is because of the better "steel" they are using compared to the other cheaper brands. Using 5 years without any issue.
skinergy
I have been using Philips AIr fryer when it first came out, more than a good 5 to 6 years and using it to cook whole grilled chicken at least once or twice a week. Very good! But I think the mesh wire on the new models now are removable.
jodyyeoyeo
If you're willing to fork over the cash, the Philips air fryer has a great reputation and a simple screen interface. Philips Digital Air Fryer very good
jennlimm
Anyone try oven air fryer ?
I just got this Mayer Air fryer oven from Shopee cause they just had Mayer day for GSS and i could get it on installment...
so far so good la, esp since i don't have the regular oven. got the tray to collect all the small pieces of food so easy to clean, I'm happy!!
RyanJ
HD9240_90-RTP-global-001
sometimes wish i gotten a bigger one.
galant22
i was gifted a phillips years ago, used it for a few months and gave up. the coil is hard to clean (cut my finger once). grease builds up and it stinks if you dont clean. finally decided to give up air frying and go for oven baked instead.
i'm still on the lookout for something easy to clean, please advise if there are any.
smurfzzz
Why need to clean coil? I'm using $40+++ Mayer air fryer, the results are similar to my old expensive air fryer ($200+++)
