Nvidia Shield TV
chubbytoes
just bought my Nvidia Shield TV box and installation was simple, HDMI to soundbar HDMI-In and soundbar to TV ARC HDMI, TV remotes controls on/off of all 3 equipment plus volume and the D-pad also controls the selection on the Shield box... happy with it.
tried to play some games on the Shield, some games tells me latency too damn long like over 256ms so cannot work but others like Stickman soccer and Asphalt racing can work smoothly over my home 1Gbps internet.
Got it locally from a shop in Wcega building with a local 12 months warranty.
chubbytoes
Hi guys have 2 questions hope you all can help.
1) can viu app be installed on nvidia shield tv? Heard that some mobile phone apps dont work on shield tv? And I think viu app is mobile version in the android playstore.
2) Which nvidia shield tv is the latest one? Read that the newest version seems to be 2017 with an nvidia shield pro being the latest. Saw lazada ppl selling 2019 version which seems like the 2017 version
was researching the same as well and believed that the 2017 is the latest as they pump in all the good spec stuff into the 2017 and therefore it still performs like a beast today. rumours there is a 2019 version but saw on youtube the spec is also the same... i suppose its the software dept they kept beefing up over time
imacbie
there is suppose to be a new chip in the work for the TBA revision.
@ichitaka_10 ,, viu wont work nicely iirc. just install on ur mobile device and cast to the shield.
chubbytoes
has anyone managed to pair a XBOX360 controller to Nvidia Shield? if i get a PS4 controller, may i know how to pair it to the Nvidia Shield? Thanks.
BiggieZee
Press n hold ps4 logo n share button till back light flicker. On shield settings, add accessory. It will show ur controller
BiggieZee
When u play hdr videos using dat setup, ur tv shows hdr logo? For me, my hdmi arc is not hdr supported. Wen using the setup like urs, my tv told me to switch to other port dat support hdr
twist_shout
Hi, anyone facing their game controller battery drain?
I have a full charge And I stop using the shield like 1-2 weeks . When I use the shield again, it prompt me battery low need to charge . Is it normal ?anyway to ‘off’ the gamepad?
Otokiru
i side load toggle app, but black screen come out nia, any1 know how to fix?
//Edited
found old post regarding shield not supported... any work around/hack available?
alwaysbehind
help! recently I cannot cast my phone youtube or any other. I have cleared the cache/cookies in the chromecast app but still same, phone can find the shield device but just cannot connect.
Pathfinder
have you tried rebooting your phone and shield?
gregory_choo
If your problem is only with youtube, you can ignore the problem and use other way to cast youtube. Just need to pair your phone's youtube with shield's youtube.
alwaysbehind
i even dloaded google Home and tried, cannot find device (shield).
yes..restart both and still same.
As for shield, google assistant is ON, cant see other settings require.
