Oneplus 7!
sushimonster
Those who bought from Geekermart, got issues have to send back to HK?
I thought they have office or middleman in SG. If not have to pay gst if the set is sent from HK.
jtec14
Yes ship back for warranty, not sure if they reimburse shipping if under warranty.
2nd question read the q & a.
imacbie
7 Pro users...
for anyone who prefers the close to naked feel.. and just wanna protect the phone from minor scratches and bumps.. i highly recommend getting those generic cheap tpu transparent casings from ebay or shopee.. few bucks for 1-2 pieces.
way way slimmer then the stock case and much much more comfort to hold.
am 95% sure it'll fit all temper glasses but i cannot confirm that. i've switched to hydrogel film after 2 trys with self applied loca tpg. application was ok. but the stock case was too tight and made some edges lift.
there is about 0.5mm of "lip" around the back camera to "protect" the lens
and for the front.. the lip is so minor i doubt it even helps.. but hey .. u've got your screen protector there.
just throwing this out for pple looking for such "protection" cheers!
WhiteAnt
For op7 who didn't use the faster updater method, there is official 9.5.7 ota available for download :o
2xEng2xCheng
Can't decide to go for 7 or 7 pro. Any suggestions? Is it really worth for the 100+ more for the pro?
Sent from Xiaomi REDMI NOTE 5 using GAGT
tott_2003
Its worth to go for op7 pro in every aspects.... Op7 non pro is no diff from op6t. If you are budget conscious then go with op7.
MGeaR356
No pro no talk, 90hz screen + qhd.. For once I don't have to envy Samsung flagship
waterballoon
Depends on your needs. 7 Pro can be very overkill. It's also very heavy, very big, very bulky and the curves on the screen are quite extreme.
Normal 7 is "safe" since it looks almost exactly like the 6t which again looks similar to the 6.
