Check in baggage exceeds
rollanddie
Anyone ever exceeds the 40kg max check-in baggage?
Will the extra weight be rejected completely?
patryn33
Just offer to pay, extra weight fee May cost more than checking in another bag.
Check your airline!
In USA checking in an extra bag cost usd$30 but over weight cost usd$100!
rollanddie
Check your airline!
There is an option to check in another bag?
The info I gathered from Google is probably to pay the exorbitant per kg fees
ApeTruelove
One luggage only allow maximum 32kilo if i am not wrong. If excess your luggage allowance then pay lor but will be very expensive de. Seen someone pay before thousands over for the excess luggage
patryn33
32kg is a lot! It’s usually 50lb or 23kg. I think you got it mixed up
rollanddie
Yes, the max weight for a single piece of luggage is 32kg.
I'm more worried about exceeding the total 40kg
rayban
Same I one bag 30kg now I separate into two baggage to check in.
