You find the hub troublesome?
too much hassle just connect and disconnect. prefer just directly. i used once and decided to look for lightning cables.
Sadly I do. And in particular, I need a plug for Australia. I could, of course, just use a standard travel adapter, but it would be nice to have a 'streamlined' charger if I could.
But like that you have to all usb c stuff? Like external drive etc. Everything need to up grade haha
If I am not wrong the 65w is shared between the ports or the USB C port may only support up to a certain wattage, meaning it will not be charging at the full speed of 65w.
I also suggest getting those single USB C adaptor because if the price. For example the price of a xiaomi 65w is selling for less than $40 in shopee:
https://shopee.sg/Original-Xiaomi-65W-USB-Type-C-Power-Adapter-Wall-Charger-i.67017280.1460711304
If you need to travel, just get those travel adapter which after adding the price of the xiaomi adaptor will still cost you lesser than the price of Mazer EnerG Travel.
If need to charge other mobile devices, I suggest to a separate adapter with 4 or 5 usb ports.
I notice I got a Xiao mi 45w pd charger and 良值 51w one. Cannot use on macbook lol. Was meant for my switch
So how? Ugreen? Hooto? Or baseus?
Hmm which build is more metal? Dun really like plastic cos scare overheat...
Hootoo any day for me
https://s.lazada.sg/s.596E
My Friend got the Anker 5 in 1 also good build quality.
yup, just cables.
Many argued that best not to for ventilation Ok will order this.
Btw is it necessary to buy keyboard protector?
I am still searching for suitable macbook case zzz
Can link the cable that USB 3 to USB c? Buy one to use first while waiting the hub
Go SHOPEE do a search USB to USB c and will return you a lot of adapter that you can use with your existing cable. I think this is the cheapest way.Can link the cable that USB 3 to USB c? Buy one to use first while waiting the hub
Very subjective.
I won’t recommend though since typing without a plastic layer gives me better experience in terms of speed and comfort.
MacBook case can get Moshi thin case but expensive. I’m just using Supcase rugged one. Don’t think is a must alsoMany argued that best not to for ventilation
Saw some. want to see which bro buy here already get the same kind at least know it working kind.
