Need Advice on Gaming Rig
dormito
Hi all,
Decided to set up a new thread. My old thread as below:
https://forums.hardwarezone.com.sg/hardware-clinic-2/recommendations-gaming-desktop-6011387.html
In summary, been a laptop user for 10 years. Thinking of changing to a desktop with a wide screen.
Using mainly for gaming, Netflix and torrents. Was waiting for Ryzen 3000 series to be out. Budget about 3K.
The current recommended build is:
Main Processor - AMD Ryzen 3600+MSI B450 Tomahawk Max series
Graphics Card - GALAX RTX 2080 8GB BLACK O.C or GALAX RTX 2070 8GB EX WHITE
Memory RAM - CORSAIR VENGEANCE LPX 3200MHZ CL16 ( 8GBx2pcs )
Display - Prism X340
Storage - SAMSUNG EVO 860 250GB M.2 SSD + TOSHIBA 2TB 7200RPM 2YRS P300 RED
Casing - NXZT H500 chassis or C.M MASTER CASE MB520 RGB T-GLASS with 3 RGB fan
PSU - 550w - 650w EVGA G+ 650W 80+ GOLD 10YRS
Audio - Onboard Realtek ALC audio
Cooler – Heard Ryzen 3000 series will be very hot and will need a cooler Any recommendations?
OS - Windows 10 64bit
Planning to go to PC themes at Sim Lim Square to build the rig. Any advice will be much appreciated!
Rashkae
I recommend Ballistix over Vengeance for the RAM.
For main boot storage, go NVME M.2 instead of SATA
Cooler: Ryzen is colder than Intel. The stock one is fine but can get loud. Can consider a 212x
dormito
Thanks for the reply!
Sorry but as I am very noob in this hardware thing, possible to specify exactly which hardware you recommend?
Rashkae
Ram: Crucial Ballistix 3200 cl16 2x8gb
M.2: Adata XPG PRO SX8200 512 GB
Cooler: Cooler master Hyper 212x PWM
andymarsh
@dormito
Your list (and all the recommendations here) is good. Some parts are likely out of stock (e.g. Tomahawk max), so do have some backup in mind before going down.
Otherwise, SLS shops tend to push other 'more costly' alternatives to you.
dormito
Thanks ! Updated my build as per recommendation
Memory RAM – Crucial Ballistix 3200 cl16 2x8gb
Storage - Adata XPG PRO SX8200 512 GB
Cooler – Cooler master Hyper 212x PWM
dormito
@dormito
Haha Not really in urgent need to build the rig immediately. Waited since May 2019 for the Ryen 3000 series
Guess the Ryzen 3600 and Tomahawk Max hard to have alternatives?
Psycovirus
Hi all,
Hi, You can use the stock Cooler just fine. If you wish to change to a better cooler, go with Cryorig H7 Quad Lumi or just H7.
Change GPU to the new Nvidia GTX 2070 Super. It performs very close to 2080 while much cheaper than 2080.
dormito
Thanks for the advice Updated the build as recommended
Graphics Card - Nvidia GTX 2070 Super
Cooler – Cooler master Hyper 212x PWM or Cryorig H7 Quad Lumi
andylau78
Roughly how much ?
Psycovirus
Main Processor - AMD Ryzen 3600+MSI B450 Tomahawk Max - $476
Graphics Card - GALAX RTX 2070 Super 8GB - $759
Memory RAM – Crucial Ballistix 3200 cl16 2x8gb - $111 (Newegg)
Display - Prism X340 - $599
Storage - Adata XPG PRO SX8200 512 GB - $133
Casing - NXZT H500 chassis - $119
RGB Fans - Tecware Arc F1 RGB Fans Starter Kit - $39 (lazada)
PSU - 550w - 650w EVGA G+ 650W 80+ GOLD 10YRS - $159
Cooler –Cryorig H7 Quad Lumi -$94
OS - Windows 10 64bit (Just search on Carousell) - $8
Damage around $2497 estimated
MakiMaki
Lol Not sure Hope only 3K +
Since you still have some budget to spare.. do consider looking at other options for your display. There are lots of better options out there if you increase to around $1k. I’ve seen X34Ps going for <$1000 at times even.
MoneyFace =p
CPU+MB: AMD Ryzen 5 3600 + MSI B450 Tomahawk MAX @ $476 (PC Themes)
WC: NZXT Kraken X62 @ $197
RAM: G.skill Trident Z Neo DDR4-3600 CL18 16GB [Black] @ $189 (Newegg SG)
GPU: Galax RTX 2070 Super EX OC 8GB GDDR6 [White] @ $759 (Corbell)
SSD: ADATA XPG SX8200 Pro 512GB [NVMe M.2] @ $129
HDD: Toshiba P300 2TB [7200rpm] @ $77
PSU: Seasonic FOCUS PLUS Gold 750W [80 Plus Gold] @ $164
CASE: NZXT H500 [Black] @ $114
OS: Microsoft Windows 10 Pro 64-bit Product Key @ $3 (Taobao)
DSP: Acer Predator XB321HK 32" 4K 60Hz G-Sync IPS @ $763^°
FAN: NZXT Aer RGB 140mm X2 + HUE+ Controller @ $99
RGB: NZXT Hue+ Extension Kit @ $34
GRAND TOTAL: $3004
Prices from Lazada unless specified.
*after Lazada DBS/POSB $10 off min $80 spending Bank coupon [TBA every Thursday]
^after Lazada DBS/POSB $30 off min $300 spending Bank coupon [TBA every Thursday]
°after Lazada SAFRAPERKS 8% discount max $5 Cart promo code [Ends 31/08/19]
dormito
Thanks for the price estimation! Planning to get it done at PC themes
dormito
Prism X34 not good? Do you have any recommendations for widescreen display then?
dormito
GRAND TOTAL: $3004
Wow Thanks for the recommendations!
Was planning to get from PC themes as I dun know how to assemble myself haha
SkyShroud
Can't comment on monitor, a lot of monitors on market and sg isn't exactly a place where you can get latest monitor easily either. It is better to source oversea if you looking at high end monitor unless there is a awesome local deals which hopefully someone do keep track and can advise on that.
Anyway, if you are using it for gaming, I would suggest to up your ssd to 1tb.
Games are becoming more space hungry.
If you not oc-ing, no reason to spend much on cooler. I would recommend diverting much of those money on other parts.
