Genting FAQ - Part 3
Paul Lee
If the dealer get the straight flush, even if she doesn't occupy the slot before you, you also won't get the straight flush, isn't that right? The straight flush is yours only if the auntie got the straight flush immediately on taking the slot before you.
Interesting observation and when I tried to work out the sequence on paper, it seems you are right. :s13:
I think I got my story slightly wrong, I think what happens was that the auntie sits down on the table and decides to skip a hand. If she had played, I would end up with the dealer's straight flush. Make sense?
Anyway, you played at the table long enough and all memories of the games you played seem to merge and overlap :)
Paul Lee
Well, there is a reason why you get more GP for the slot package. As you say, the odds are worse.
I'm not sure why other members buy the golden package. For me, it's not really to 'wash' the chips.
Since I am prepared to play at least RM500, it makes sense to buy the Golden Package for the extra meal (worth ard RM20 which is already 4% of what you pay for. It goes up to 6.7% if you just buy the RM300 package). Sure the extra 1 or 5GP is not a lot but it still better than nothing.
One more thing about playing with NN chips at the Roulette table is that the lowest denomination for the NN chips is RM25. Whereas the min you can bet on the single number at the Roulette table is lower rt? (RM10?)
Frankly, I have never seen anyone just betting 1 single number per round at the Roulette table :s22:
vaxvms
Bro - vaxvms is a butterfly, go make 1 round then come back see result type 😁
dun need cum back
just hear sound or crowd disperse or not can already
i do sit for a deck when tired...
now easy standing also can put card
some sup vali good recognize me help me put card from table to table
Smarty2
dun need cum back
....big big 🐋🐋🐋 is like tat one 😁....👍
Smarty2
Lol... same with me on reason to buy NN pkg - it's for the meal voucher since i alrdy set aside some $$ to gamble anyway....it doesn't make a difference for me - might as well get free makan..
Betting on a single nbr on roulette is almost a sure way to donate $$ without high expectation for a return... personally i wud not do tat...
Smarty2
Whether you bet 1 number or 20 numbers per game, the house edge remains the same. You cannot change the house edge by betting more numbers.
Lol...can u enlighten us fr your statistical/ logical point of view? Just for sake of discussion only la ya? - u r saying betting even on 34 nbrs is not any better than just on 1 nbr?..mind boggling really ******************
U dun mind share with us any source on the internet tat advocates such a "strategy"?...
Simonlee1977
Hi all,
Anyone can enlighten me on the golden package or the link I can go and have a look.
My normal bet is 200 to 300 on sicbo.
Tq
Paul Lee
Hi all,
Tq
Here you go >> https://www.rwgenting.com/casino/highlights/Genting-Golden-Package/
200 to 300 per hand? Then even the RM500 package is not enough for you. :s13:
Also, take note that the process of getting the Golden Package is a little bit troublesome.
#1 You need to go to the membership counter and tell the staff you want to buy the golden package (or the bus program as they called it). Be sure to specify that you are playing table game. You will receive a few printouts including the meal voucher. (Take note that the meal voucher is useless at this pt)
(Tip: On the 2nd floor, the extreme right queue is for buying Golden Package. So you need not queue with the rest. Unless you kenna travel agent processing a stack of cards, then it may be faster to join the general queue)
#2 Take all the slips and meal voucher, go to the cashier and pay for the package. You will receive another voucher (printed on thicker paper) if you are playing table game. If you are playing slots or ERG, then the credits will be credited into your card. Make sure the meal voucher is validated by the cashier.
#3 Take the printed voucher to any gaming table with a scanner. Hand over the voucher and card to the dealer and he will exchange the NN chips for you. You are good to go!
(Tip: Check that the table has a scanner and the required NN chips before presenting the voucher. I usually try to go to the less crowded table for this so as not to impede the game in progress)
Simonlee1977
Thank you for the detailed information.
1 last question.
Can the chips be used on different tables or must be on the same table
Thank you in advance
Paul Lee
1 last question.
The NN chips can only be used at SkyCasino General Area. They can be used at all gaming table of cos. :)
You cannot use them in the SkySilver (and by extension SkyGold).
Broadwalk
Me... Anything to take note :(?
Sent from Xiaomi REDMI 5A using GAGT
Tell you a bit scary one.:o I stay in the standard room then on the last day I book out I went on TOP of the shelve that keep clothes to remove and pack my smelly cloth I saw amulet those thai hard amulet lying on Shelves.:o
I see Liao I act blur and go out immediately.:o
rottingapple
I havent book anything yet... :o
Maybe i should just go aegean paradise instead :(
ghregular
Wizard of Odds has a good FAQ on roulette.
https://wizardofodds.com/ask-the-wizard/roulette/
In his second point, he states that you do not change the house edge in roulette by different bet combinations. The exception to this is a special combination bet which significantly increases the house edge.
Roulette players who don't understand this often lose large sums of money. The common misconception is that you are playing 'safer' if you buy more numbers. Let's look at a simple example to illustrate this. Suppose we both go to Genting with RM 5k. We play at a RM 20 table. I bet 1 number (RM 20) while you bet 10 numbers (RM 20 x 10= RM 200). We both play exactly the same number of games. After 3D2N, I will most likely leave with a smaller loss than you. This is because you are betting 10x what I am betting. Your expected loss is therefore 10 times mine. If I am down RM 200 after the trip, you can expect to be down RM 2000.
can this analogy be applied to slots too?
max or min bet?
