MBP accessories
Proximus
Hmm if skin... do u guys still use sleeves or those zipper case to store the macbook when going out or at home? Since skin does not protect against accidental dents...
My travel Tumi have laptop compartment to store it when I commute.
rayban
Now Herschel sleeve 30% off in lazada
rayban
Hinge ba
I think it come down to how well you take care the macbook too. It rough user than hard case better
Hmm will meh? My wife use similar case never have dents...
d3n
My case finally here.
AlvinDj
Can anyone intro any decently priced USB-C Hub for MBP 2019?
Will buying from Taobao more worth it or?
d3n
i using hootoo, not bad... u can try shopee price quite good
discoburg
Any good clear cover to recommend for the MBP 13"?
Bought one in Carousell and it don't feel good. Alway open ups when I lift up the screen,
yotoden
Hi, can anyone advice which 3rd party USB C charging cable is good for Macbook? Has anyone using Verbatim USB C 3.2 before?
athletic91
same, i wonder if the apple $29 usb c to usb c 1m cable is good enough for charging mbp 13
