Need Advice on Gaming Rig
dormito
Would need more advice on choosing the monitor...
Considering Acer Predator X34P vs Acer Predator XB321HK 32" 4K 60Hz G-Sync IPS
As mentioned, planning to use more for gaming (MMORPG and AAA games like Witcher 3 or Skyrim) and Netflix
Wanted to get 4K for the resolution but worried my GPU (GALAX RTX 2070 8GB Super) unable to support
More advice or recommendation for display will be appreciated!
zhihao57
Would definitely recommend you going for ultrawide, it's a different experience.
Changed to ultrawide(aw3418dw) a few months back, no regrets!
zacky1223
I also agree. :) Go UW and never look back. But it's up to your preference. Better to down try before making the decision.
dormito
Currently planning to get Ryzen 3600
Any point in getting Ryzen 3700x ? Or is 3600 enough ?
MoneyFace =p
By the time you are still pondering between both models XB321HK promo price already over. Now back to $998. :s22:
You also need to be a little more trusting to others...
dormito
Really appreciate all your advice so far!
Not say dun trust you. Just dun want to rush into purchase. Scare I regret later.
dormito
Thank you for all the comments and recommendations esp MoneyFace
This will be my final build (Prices from PC themes)
Main Processor - AMD Ryzen 3600+MSI B450 Tomahawk Max @ $476
Graphics Card - GALAX RTX 2070 8GB Super @ $759
Memory RAM – CORSAIR VENGEANCE LPX 3200MHZ CL16 ( 8GBx2pcs ) @ $142
Display - Acer Predator XB321HK 32" 4K 60Hz G-Sync IPS @ $998 at Lazada
Storage – ADATA XPG SX8200 Pro 1TB [NVMe M.2 2280] @ $255
HDD: Toshiba P300 3TB [7200rpm] @ $106
Casing - NXZT H500 chassis @ $119
PSU - Seasonic FOCUS PLUS Gold 750W [80 Plus Gold] @ $169
Audio - Onboard Realtek ALC audio
Cooler –Cryorig H7 standard @ $60
OS - Windows 10 64bit
Total Damage : $3084
Hopefully, it will last me for the next 5-10 years hahaha
Will be going down to PC themes tomorrow
Any last comments are appreciated!
PS : Any recommendations for keyboard and mouse?
Solojaywalker
the $3084 including OS? if not can opt out of it
andymarsh
That's a pretty solid list. For many of the individual components, can probably get cheaper (with vouchers) online. Bargain abit for lower price since you buying the whole bundle from pctheme.
dormito
PC themes can bargain? I always thought it is fixed price hahaha
tigerwoods
I would get a Ryzen 3700X for this setup. Future games will be utilising 8cores.
